Tiver43809 Posted November 2, 2024 Report Share Posted November 2, 2024 2013 Dodge Journey Se with 2.14 engine. I was having overheating issues. I replaced both thermostats, but it was still overheating. Yes, I burped it. I noticed the radiator cap was torn up. I replaced it, and the car had a hard time starting, and once it did, it was blowing white smoke/steam. I have called around for a head gasket replacement, and two places said I need to replace the engine. I asked for mechanic suggestions on a town page, and some guy PM'd me and said I must replace the engine. I have fixed several head gaskets without replacing the whole engine, and they worked fine. Is this something with Dodge Journeys, or are they selling me a pig in a poke? How time-consuming is replacing the head gasket in a 2013 2.4 engine? Thank You Terry in McMinnville Quote Link to comment Share on other sites More sharing options...
Tiver43809 Posted November 4, 2024 Author Report Share Posted November 4, 2024 Has no one else had to do a head gasket in here? Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted November 4, 2024 Report Share Posted November 4, 2024 Instead of asking again about a task that PROBABLY has been posted of being done by a member here, did YOU spend any time looking for postings of this task being done and what they found? There are many variables with a bad head gasket job that can only be determined as to outcome once that particular motor in question has been "opened up", AND it is a BIG job that most normal owners would NOT tackle. AND a lot of shops do not want responsibility for if held to just put in a new head gasket and it does not work. Example being bad rings/piston from antifreeze being burned/cracked or warped head/block. Good luck to you in how you proceed. larryl 1 Quote Link to comment Share on other sites More sharing options...
Tiver43809 Posted December 6, 2024 Author Report Share Posted December 6, 2024 I must be bad at searching I have looked for the last 45 minutes. OK replaced head gasket and put in new timing chain. Old chain looked and felt fine but I figured I was there. Car is running GREAT, no overheating starts and drives just fine. But it is showing P0016 and P0017. I found the post about resetting the PCM. That did not work any other ideas? Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted December 6, 2024 Report Share Posted December 6, 2024 Good to hear that you decided to "tackle" the job and seems to have worked out well for you! BUT for your 2 posted error codes {1} go back in and recheck crank and cam timing marks {2} may have to do cam sensor and crank sensor "relearn", which requires a high end scanner Quote Link to comment Share on other sites More sharing options...
