Intermediate shaft
Steven1961
I Have a 2016 journey that needs a new intermediate shaft on the right side it is leaking where it goes into the transmission /transfer unit I am looking for that seal but unable to locate one or what the actual name of it is also looking to know if i can install it myself
Which engine ? It’s a transmission input shaft seal.p or C/V shaft lip seal, various names used. They are around $25 shipped on Rockauto, the largest on line parts site.
How many car repairs have you completed; around same difficulty as a water pump replacement. New seal can be tapped in with a very large diameter socket that is same size OD as the seal. . Specialized seal driver set not really needed if your careful. Lubricating new seal with Tran fluid is critical before new shaft is installed into tranny. A few uncommon things like a 32 mm cv shaft axle nut socket will be needed.
