Hoppingyak76 Posted November 5, 2024 Report Share Posted November 5, 2024 Alright so I have a 2009 Dodge Journey SE, 2.4L il4, automatic transmission. Unfortunately, my motor blew up yesterday while I was driving along(i had just started moving after having stopped, and I had barely hit 20MPH @ 3k RPMs when my motor locked up and my crank case decided it wanted a new window). I'm debating on putting a new motor in it because it's my only vehicle at the moment and I can't afford a new one, which leads to my question: how hard would it be to swap out the old 4Cyl for the V6 that came in the higher trim models? Are motor mounts/wiring harness connections/etc. the same? I know that the Journey was more or less built for everything to be as cheap and cookie-cutter to assemble as possible, but I HATED how sluggish my 2.4L was, and would like to have some more power to work with. At the end of the day, I'm on a SUPER tight budget and literally just need to be able to get to work, but if the price difference and amount of extra labor involved aren't too outrageous, I figure I may as well turn my Journey into something that I can actually stand driving. Any advice/information is valuable and appreciated, thank you in advance! Quote Link to comment Share on other sites More sharing options...
larryl Posted November 5, 2024 Report Share Posted November 5, 2024 It would be outrageous if you have no money as you would also have to change the tranny as they are different and the 09's had a 3'5 not a 3.6 so you'd be hard pressed to find one. Basically a pipe dream look for a 2.4 Quote Link to comment Share on other sites More sharing options...
luzmina Posted November 5, 2024 Report Share Posted November 5, 2024 Is better to find a used 2.4 and put it there, but there is a difference between the 2009-2010 and 2011-2018 2.4 in the intake, probably they use a different PCM, so you will need the intake of the 2009 for the swap, I have a 2.4 and I am happy, I just need a transportation no a race car. Quote Link to comment Share on other sites More sharing options...
