P0302 Code then....overheating. HELP!
Hey whats up everyone,
I'm having a few issues and hoping someone can guide me on what to do next, I turned on the car last week and the engine vibrated for like 30 seconds and then a check engine light came on. It's a 2019 Dodge Journey SE 4cyl 2.4
I got 3 codes.
-P0302 CNF MD00
Cylinder 2 Misfire detected
-P0302 PND M0D00
-P0302 PRM M0D00
So I took it to my local mechanic and we replaced all 4 spark plugs, 2 were really bad. But a few days later the car started overheating after 30 mins of driving. I checked the radiator fan, and it comes on when the temperature is reached (approx 200-220), no smoking or etc. My dad and I also inspected the hoses for leaks, tears, all clamps and connections....no issue.
Any ideas on what this could be or what we should check for next?
your plugs should be changed every 30 k ,iles also only use OEM plugs they are cheap and easy to replace as far as the overheating exactly what happened how hot did it get? did you lose any coolant? probally you just need to replace the thermostat unit on your journey I believe there are 2 of them in the plastic unit as I have the 3.6 and it is a different type that is used instead of the 2.4 only use Mopar coolant when adding to your cooling system...good luck
We did use the OEM spark plugs (copper), as for how it happened it just popped up. We were just driving a few days later and the overheating sound and dashboard light came on. I pulled over and waited 20 minutes and drove it home. As soon as I got on to the block, the over heating light came on again. The car runs and drives fine with no issue, but as soon as it gets to 25-30 mins.....over heats.  But just to clarify there is no leaks, smoke, loose connections or etc.
2016 DJ, Code definition
2.4L engine.
P0302-CYLINDER 2 MISFIRE
When Monitored and Set Conditions.
When Monitored: This diagnostic runs continuously when the following conditions are met:
• The engine is running.
• The adaptive numerator has been successfully updated.
Set Conditions:
• The Powertrain Control Module (PCM) detects that the variation in crankshaft speed between each cylinder exceeds a calibrated value, based on engine rpm and load.
Default Actions:
• The MIL light will illuminate.
POSSIBLE CAUSES
FUEL DELIVERY SYSTEM
IGNITION COIL, WIRING, OR CONNECTORS
ECT SENSOR, WIRING, OR CONNECTORS
MAP SENSOR, WIRING, OR CONNECTORS
02 SENSOR, WIRING, OR CONNECTORS
ENGINE MECHANICAL SYSTEM
POWERTRAIN CONTROL MODULE (PCM)
2. DIAGNOSTIC INSPECTION
NOTE: Anything that affects the speed of the crankshaft can cause this DTC to set.
NOTE: When a misfire is detected, the PCM will shut down the injector control circuit for the misfiring cylinder.
NOTE: Misfire may occur and may not be caused by component failure. Any of the following conditions can cause a misfire:
Worn serpentine belt.
Misalignment or binding water pump, P/S pump or A/C compressor pulleys.
Improper CKP, CMP, MAP, or TPS Sensor mounting.
Poor connector/terminal to component connection for CKP sensor, CMP sensor, MAP sensor, TPS sensor, fuel injector, ignition coil, etc.
Corroded PCM power or ground circuits.
Vacuum leaks.
Restriction in the air induction or exhaust system.
Internal engine component malfunction.
Moisture on ignition system components.
Insufficient fuel.
Low quality fuel.
Manual transmission bog.
Towing overload.
22 hours ago, 5rebel9 said:
I'm not sure which size engine is in your car. IF a 4 cyl, then a possible stuck shut thermostat{it has 2}. BUT I also suspect you may have a blown head gasket.
It's the 4cylinder 2.4L model, and I'm REALLY hoping its not a blown head gasket.  Any signs I should look for if its a blown head gasket?
Edited by DodgeBruhBoy
2.4L engine.
Set Conditions:
Default Actions:
POSSIBLE CAUSES
Vacuum leaks.
Insufficient fuel.
Low quality fuel.
Towing overload.
Thank you for sharing, I appreciate that. I'll review everything and report the results soon.
Being the 4 cyl. the easiest way is to pull the spark plugs again and compare #2 plug to the other 3 looking for tip damage or clean wash compared to slight darkening of the others.
I learned this "trick" WAY BACK in my YOUTH.
IF all look the same, then you may have a coil going out and a stuck shut T-stat.  I would suggest replacing BOTH stats at same time.
Ok, thank you very much for the response. Ill check tomorrow when I get in.
Update: I ended up taking the car in early this morning and just got a call from my mechanic, and he said he went through the car, drove it, let it run and etc and no overheating at all. He said there is no leaks, smells, or anything. He did say that the coolant was low, and put in a half gallon but right as of now, there is no over heating after an hour of driving and letting it run.
Any suggestions?
Unfortunately i had this same code with cylinder 2 a few years ago on my 2013 SE 2.4l and it was the head gasket. i had a little over 71K miles and the extended warranty i purchased ended at 70K. i was not happy as it was a $1,500 repair but i paid it. I wrote to Dodge customer service and they issued me a check for half the cost. I had the repair completed at the local dealer and had to send Dodge my invoice. I felt somewhat better about the situation but still upset the head gakset failed after 5 years. Good luck with your Journey.
Specifically ,
You need to check the coolant level cold and after being driven full hot.
You need to learn how the coolant level changes.
Then check it daily.
While your checking your
coolant.
Check all your fluids and hoses.
Know what is going on under your hood. Before you go driving.
Go read this post below, I made regarding maintenance.
It's up to you monitor this situation.
The Journey's engines cannot take too many overheats.
Before it's scrap.
Edited by Dean H
On 11/21/2024 at 11:29 AM, 5rebel9 said:
Well, after a shop has checked it over like you post.
Drive it AND monitor for misfiring coming back and CEL AND monitor interior heat quality{low coolant will cause low heat} drive the car as normal and keep a check on fluid levels under the hood.
I have been driving it every day, and there has been no CEL, misfiring, or overheating. The heat seems to be working fine as well. Am I only checking the coolant reservoir? Or rad cold as well?
Oh wow, mine is a little over 74K miles as well. Same 2.4L and everything I do have a warranty through carvana but I heard its junk, that will be the next step if an issue arises again.
Oh wow, dodge actually paid for half? Yeah if it blows at 5 years im gonna be pissed.
On 11/21/2024 at 8:14 PM, Dean H said:
Specifically ,
coolant.
Before it's scrap.
Ok, I will read it right away and will check it first thing in the morning cold. I have been driving it every day, and its definitely been over 5-6 hours of drive time and no issues at all. Ill read the post now and post back if I have any questions....if thats ok.
Glad to hear everything is good with your Journey.
Post back anytime.
Check the coolant level at both places.
When you check the coolant level cold, in the radiator.
Check the 2 rubber seals on the cap it's self. If not intact.
Replace it.
The cap pressurizes your cooling system.
Edited by Dean H
go ahead and check it cold if needed to add some go ahead and add some THEN mark it real good with a black marker at the cold level and then later on after running it normal amount of time and then mark it again after it has set a bit to show the full mark and then check it every day for a couple of weeks and then once a week after that  also a good time to check all the other fluids like power steering and brake fluid and the oil level
