caliper compression tool?
doing brake job on my 2012 Crew 3.6 FWD, rear caliper piston won’t compress. i see 2 indentations on the piston head so im assuming is has to be turned? if so what tool do i need? i had a regular clamp but it only did justice for the front pistons.
Yes, the rears have to be pressed AND turned in to bring the piston back into the caliper. The so called "universal" cube does NOT fit the the dodge caliper pistons, ask me how I know having 4 of these cars!
Parts stores with tool rental should be able to "hook you up" with the needed tool.
yeah, tell me about it! i have 2 journey and did one thinking something was wrong just to do this one and have the same issue, lol. thanks, i’ll see if they have one for me to buy because again i need to do both.
the cube worked on my 2014 with no problems
harbor freight would be the cheapest place for the tool
OKAY, YES if piston is not in any way "sticky" the cube will "make do" work. BUT none of the sides are a really good fit . YES on my first set of rear brakes{the'11} I made it work, BUT the proper tool works so much easier and less hassles of trying to press and turn with a ratchet/extension . I would suppose anyone outside the Northeast "rustbelt" area would also be able to make the "cube" work for a one time deal, but I will go with the proper tooling as stated by 2late4u and have the set from Harbour Freight .
    Also: note the "cube" I have is 20 some years old now and MAYBE they have updated the cube by now.
Note: that for my Buick..... the cube works perfectly, but the HF kit covers a multitude of vehicles.
Edited by 5rebel9
i would’ve tried them or went somewhere but im literally driving w no pad left lmao. ikr, how’d i let it get that bad. i just did the front so i should’ve done all but again wasn’t aware the rear needed a different tool. i ordered one online and it should be here soon. i have the pads too so hopefully all goes well!
10 minutes ago, yyz said:
In a pinch I have used needle nose pliers
 i thought about those too, i didn’t have any but the tool just got here and ofc it would be when it’s barely daylight 🙄
1 hour ago, diymirage said:
Just watched a video on it, that is absolutely retarded
Just asking on why your thought on the subject. using makeshift or the proper tool? MANY cars with incorporated parking brake in the rear caliper have been around for at least 20 years now. And all have different "variations" of size pin/slots to engage the caliper pistons. Sure beats trying to get at traditional seperate under the disc hub parking brake shoes.....especially in "the rustbelt" Northeast!
im sure there are, but this is the first one i ever dealt with that couldnt just be ran back in
even my old VW, which had an electric park brake (you push a button and a servo would "turn" the piston and apply pressure, when you let off the brake the piston would run the opposite way and release. with that design you could jump the servo terminals to any 12 volt DC source and run the piston in or out)
i have never laid eyes on a brake piston that needed to be manually screwed in to replace pads
Well, your "old" VW and many more vehicles are so equipped and are the "NEW" technology. IF you ran vehicles with as many miles/years as the one I do, when need comes to replace components you would probably scream at the price of those type calipers. Yes the Pacifica and Chrysler/Dodge minivans also went to the electric parking brake around 2017
Saab used the manual screw in pistons for parking brake use way back in the early 80's with the 99 model.....don't ask me how I know....LOL !
i have only "needed" to replace a caliper once, on the superdookie right at around 245K miles, and that was only because the piston itself had disintegrated...the caliper was fine, i just got lazy and didnt want to rebuild it
then on the duster, i switched from front drums to discs, so i needed calipers for that
but other than those two instances, i have never, ever had a caliper fail
none of wich has any bearing on what dodge, or whoever their foreign stepdaddy was at the time, decided to screw in brake pistons
