Leroy Posted November 21, 2024 Report Share Posted November 21, 2024 Hello everyone, does anyone know the specs on what size and type of bolt is used on the throttle body support bracket (2013 Journey SE). I had to replace the intake manifold gasket and discovered the throttle body support bracket bolt was missing. all i can think is about 6 years ago i had the dealership replace the head gasket and they forgot to install it. i cant locate it on any OEM parts sites or in the Haynes manual i purchased. Any help is appreciated. i may go to a junkyard and pull one if i can find a Journey there. Quote Link to comment Share on other sites More sharing options...
Dean H Posted November 21, 2024 Report Share Posted November 21, 2024 What engine do you have?, 🤔🤔🤔 Quote Link to comment Share on other sites More sharing options...
Leroy Posted November 21, 2024 Author Report Share Posted November 21, 2024 13 minutes ago, Dean H said: What engine do you have?, 🤔🤔🤔 Hi Dean, it is the 2.4l engine. thank you. Quote Link to comment Share on other sites More sharing options...
Dean H Posted November 21, 2024 Report Share Posted November 21, 2024 (edited) Post a picture of the bracket. It's going to be metric. Find somewhere that sells metric hardware bolts. Start at bolt size M8x1.25. Go to a larger or smaller sized bolt after trying the M8x1.25 bolt. Just thread it in easy to see if it is the right size. Edited November 21, 2024 by Dean H Quote Link to comment Share on other sites More sharing options...
