Jimmy79 Posted November 21, 2024 Report Share Posted November 21, 2024 I bought a set of 3 mopar transmission speed sensors on ebay and I was wanting to know if anyone has changed theirs out and can tell me exactly where they are located and if it's easy enough for DIY job. The ebay item number of the ones I ordered is 264700964245 I have a 2014 limited awd. Quote Link to comment Share on other sites More sharing options...
Dean H Posted November 21, 2024 Report Share Posted November 21, 2024 (edited) You are in luck. You can. You have to remove the engine air filter box and the intake tube from it to the engine. There is one speed sensor on top of the transmission. Hidden by the large bundle of wires. Next to where the transmission cooler lines go into the transmission. The other 2 sensors are on the backside of the transmission. Close together. You have to look over the transmission. Use a good light. Edited November 21, 2024 by Dean H 2late4u 1 Quote Link to comment Share on other sites More sharing options...
