Transmission speed sensor
Jimmy79
I bought a set of 3 mopar transmission speed sensors on ebay and I was wanting to know if anyone has changed theirs out and can tell me exactly where they are located and if it's easy enough for DIY job. The ebay item number of the ones I ordered is  264700964245 I have a 2014 limited awd.
You are in luck. You can.
You have to remove the engine air filter box and the intake tube from it to the engine.
There is one speed sensor on top of the transmission.
Hidden by the large bundle of wires.
Next to where the transmission cooler lines go into the transmission.
The other 2 sensors are on the backside of the transmission.
Close together.
You have to look over the transmission. Use a good light.
Edited by Dean H
