BRad111 Posted November 30 Report Share Posted November 30 Okay so when I bought my car I was having problems almost immediately after I bought it and I called the people who I bought it from and they said no warranty as is so great dealership anywho it first started my turn signal that controls the foggers the turn and my windshield wipers front and back I noticed that whenever I hit it or used it or anything it would activate some type of disco lights in my whole entire car where it would be flashing on and off and then my battery died so I obviously change the battery and maybe that lasted a month and my battery died again I got it under warranty so replaced it and once again got a new battery it died so after the third or battery it finally took and the car has not had any issues well it's been about good four or five months now and now I'm having other issues I have been hearing a little bit of a knock and it only started once the weather got cold they get really cold over here by the way and when it warms up it stops so I'm like okay can't check the transmission because there's no stick to check it these cars don't have little oil stickers that you can check to see if you need to add more for some reason and also these are like little tiny batteries that are underneath the wheel we're out All you have to take off the driver side tire in order to get access to your battery which is really stupid anywho back to the story I was on my way to work I left the car warm up for about 5 minutes I heard the knocking I waited until the car idled at a regular not high idle from when you first start it I put it into reverse and the knocking got a little bit louder for about 2 seconds as I was driving in reverse and it died and I can't get it to start again I don't know what the problem is I checked all the fuses it has power oh and by the way let me just cut the key fob doesn't work so when you go to unlock or lock my car it doesn't work it doesn't register but when I put it into the little dashboard whole thing it turns my car on I don't know how keep fob works this is all new to me I'm used to having a key going in the ignition that's it back to the story so now I have a car that does not work and I need help any suggestions or if anybody's come across this problem can you please tell me how you resolved it Dean H 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 1 Report Share Posted December 1 by the time I got Thur reading the story, I couldn't remember your problem,sounds like you got a lot of unresolved problems...good luck larryl, Dean H and Summer Solstice 3 Quote Link to comment Share on other sites More sharing options...
Rgant_1981 Posted December 5 Report Share Posted December 5 Wow!!! You said a lot… if possible, try to tackle one problem at a time to narrow down your issues. Ok, what I have dealt with my journey 2010 R/T is somewhat of a similar issue your dealing with… Your transmission may either be low on fluid or is dirty. Either way, it needs to be serviced. That’s the reason why your vehicle is shutting off while in reverse because it’s protecting your trans from creating further damages. As far as the key fob goes, check out a YouTube video on how to replace the battery. I hope this lil bit helps! Quote Link to comment Share on other sites More sharing options...
