No heat mystery
Wicked Jim
Hello All need some help 2012 dodge journey no hot air all blend doors working new heater core (heater core is hot on inlet and outlet ) blower motor working as it should everything checks out and I still have little to no heat out the vents no matter what setting I use any suggestions? Thanks in advance all 😊
Might be time to have the dealership OR a qualified garage check it out YES they charge a dig charge but I have always found they apply such charge towards the repair, sounds like you have covered most of what you can,time to let the pros check it out.pleaseĀ  report back on what you find out to be your problem for othersĀ  to learn from
If you have this below-
Ā
EVIC screen located in the center of the instrument cluster.
Use the keypad on the left side of the steering wheel.
Arrow buttons and the back button.
Ā
Select coolant temperature.
Ā
Report back what the temperature is.
Edited by Dean H
