JustDodge
hello, have a 12 Journey Crew 3.6. Lately i have been barely getting heat. i just flushed the heater core w clr about a month ago and have fixed the no heat but a month later here i am. it is topped with coolant but i notice i intermittently have heat. after further self inspection, checks out that is because the car isn’t always reaching operating temp or above 200°. it’s been primarily operating around 180-190. it’ll reach above 200 at idle but if i drive the temp goes down. is this a sign of thermostat being stuck open or water pump failure?
On 12/14/2024 at 9:23 PM, 2late4u said:
change out the thermostat first ,,easy to do and also the cheapest,make sure you use the right coolant as well the temp should be around 200-205 normal and go as high as 218-220 then cool back down
yeah i figured the therm, i ordered 2 of them since i have 2 journeys and ironically the same issue happened around the same time lol. hopefully this is the case, i literally replaced all cooling system components within last two years…
