Shriram Posted December 17, 2024 Report Share Posted December 17, 2024 This is the CEL code I got for my 2014 Dodge Journey 6 cyl. with 140k miles. Does anyone have any expereince deling with this ? Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted December 17, 2024 Report Share Posted December 17, 2024 Check the battery sensor on the negative post of the battery and fuse F179 {probably in the inside the car fuse panel}. most likely it is a badly corroded connection as the 2 wire plug on the battery sensor is quite small gage wiring. You may need to replace the whole sensor unit and the harness plug end. Good luck and let us know what you find! Shriram and larryl 1 1 Quote Link to comment Share on other sites More sharing options...
Dean H Posted December 18, 2024 Report Share Posted December 18, 2024 (edited) Follow 5rebel9's directions. Read my post and whole thread below, regarding the battery and battery sensor. Everything you need to know is covered in it. https://www.dodgejourneyforum.com/topic/18210-electrical-system-fyi-battery/ Edited December 18, 2024 by Dean H Shriram 1 Quote Link to comment Share on other sites More sharing options...
Shriram Posted December 19, 2024 Author Report Share Posted December 19, 2024 Thank you so much for the detailed information in the link. I will fix it now. Dean H 1 Quote Link to comment Share on other sites More sharing options...
