P058C Battery Monitor Module Temprature Monitoring Performance
Shriram
Check the battery sensor on the negative post of the battery and fuse F179 {probably in the inside the car fuse panel}.
 most likely it is a badly corroded connection as the 2 wire plug on the battery sensor is quite small gage wiring. You may need to replace the whole sensor unit and the harness plug end.
Good luck and let us know what you find!
Follow 5rebel9's directions.
Read my post and whole thread below, regarding the battery and battery sensor.
Everything you need to know is covered in it.
https://www.dodgejourneyforum.com/topic/18210-electrical-system-fyi-battery/
Edited by Dean H
