MajorPain Posted December 17, 2024 Report Share Posted December 17, 2024 So several years ago the read wiper motor started acting up. At times it was making clicking noises when turns on which made me think the gears were going bad. It eventually stopped working completely and I never took the time to fix it till now. I purchased a new motor and it was actually very easy to swap out with the old. Did a test run of it and there is nothing. I'm going on the assumption that the motor is good and then my next step was to check the fuse. Looking in my book, it says the rear wiper fuse is F115 located in the fuse panel inside passenger floor area. (absolutely nearly impossible to see) On the lid, which I'll attach a photo, there is no F115 spot. Tried looking in the fuse box area but hard to see but I don't see and extra fuses. Some extra empty slots. So anyone ever come across a fuse not being there? Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted December 17, 2024 Report Share Posted December 17, 2024 Check for broken wire in the rubber boot between rear hatch and body of the car. Quite common on our DJ's to do such and NOT blow a fuse. Quote Link to comment Share on other sites More sharing options...
MajorPain Posted December 17, 2024 Author Report Share Posted December 17, 2024 1 minute ago, 5rebel9 said: Check for broken wire in the rubber boot between rear hatch and body of the car. Quite common on our DJ's to do such and NOT blow a fuse. Thanks. So the book is wrong on fuse location. It's actually under the hood F172 and it was fine. I was checking codes couple days ago and there was a new code which I forget at the moment but I think it was related to the rear wiper park position. Guess it could be a short and not sensing anymore. Next will be the rubber boot. Quote Link to comment Share on other sites More sharing options...
