Which Posted December 30, 2024 Report Share Posted December 30, 2024 (edited) Head Unit Options OEM Head Units Infotainment carries a complete kit for swapping different versions of your OEM head unit. If you prefer sourcing components yourself you will need a new bezel, A/C control panel (also referred to as a lower stack), A/C and Heater module*, and receiver when swapping from 4.3 to 8.4 uConnect models. Head Unit Types RE2: Non-navigation 8.4” units. Does not require a GPS signal. RB5: Navigation equipped 8.4” units. Requires a GPS signal to use navigation. If your vehicle is equipped with Sirius satellite radio this should be plug and play. Parts I did my best to compile part numbers for relevant components. Please check that these parts are compatible with your vehicle before purchase. RB5 units should be interchangeable so long as it’s not from a Dodge Dart. Part numbers need verification but generally appear as “multimedia" when searching Mopar. Be mindful that there are navigation and non-navigation units. Sellers often claim the unit you’re purchasing has navigation but there is no reliable way to tell even with part numbers. You will also need additional hardware if swapping to a unit with Sirius / GPS from one without. Part Part Number Notes A/C and Heater Module 68263758AB * In case you cannot flash your existing module to work with the AUTO feature. A/C Climate Controls w/o AUTO 1RK581X9AD Center Stack Lower A/C Climate Control w/ AUTO 6MP801X9AA Center Stack Lower 8.4 Screen 05064993AG, 05064993AI Center Stack Upper 4.3 Screen P05064976AH Center Stack Upper RB5 Receivers 68209666AE, 68209666AG, 68209666AD, 5091920AB, 68209666AF, 68209666AA, 68209666AE RE2 Receivers 5091134ZK, 5091134ZI, 5091134ZH, 5091134ZJ Antenna Assembly 05091031AA Cabin Air Temp Sensor 55111178AC Sunload Sensor 68230114AB, 68230114AA, 55111902AB, 55111902AA, 55111275AA Ambient Temperature Sensor 5149264AB, 56028364AA, 5149182AB Intake Manifold Temperature Sensor Humidity Sensor 55111389AF, 55111389AE, 55111389AD, 68440808AA Rain Sensor 68587061AA 68587061AA Dodge Journey LDWS Rain Sensor Solar Windshield 4.3 Bezel 1RE271XPAE, 1RE271XPAB, 1RE271XPAC, 1UR34JXPAA 8.4 Bezel 1QC311XPAD, 1QC311XPAB, 1QC311XPAC, 1UR33JXPAA Known Issues 22 Degree Bug & Automatic Climate Control: Fixed by using the OBD Genie C-ACC Programmer or AlfaOBD and installing a climate control module with AUTO button. See Sgt. Beer Belly’s AlfaOBD thread for information on what to change where. Missing Rear Climate Controls See the Installing 8.4 uConnect (actually doing it) thread for details I may have missed. OEM Injectors Typically called Retrofit Boxes or Screen Integration. They serve to add complete Android Auto and Carplay experiences to existing OEM equipment and/or provide wireless connectivity to your system. Another option is the Lockpick which allows you to run video while in motion. Mirroring is available by purchasing an additional module. You will need an 8.4” screen to take advantage of these options. JoyeAuto https://www.aliexpress.us/item/3256801435040338.html Azton https://www.aliexpress.us/item/3256807904142761.html Sinairyu https://www.aliexpress.us/item/3256807735051445.html NAViKS Lockpick Lockpick & Mirror Interface Unbranded https://www.aliexpress.us/item/3256808018954513.html Aftermarket Head Units If you search for Android head units in general you will find several listings that provide the fascia, CAN bus decoder, head unit, and necessary cables. Information below is for your reference so you know what you’re buying, or if you’re trying to hunt down a better deal by purchasing individual parts. Units do not always come with the Android version displayed in images or the proper screen resolution. Closely inspect details in the listing description as many sellers use the same stock photos and verify when you receive your unit. They can be purchased directly from Seicane, Alibaba, or Aliexpress. Some units are available from North American retailers such as Amazon and eBay. Products originate from the same place and are typically white-labeled and marked up. Some sellers simply have distribution warehouses located in North America for quicker delivery but you can purchase the same item at a steep discount from their overseas stores. You may benefit from swapping to a climate control unit with the AUTO button and programming your vehicle if you don’t already have it. Most of these CAN bus decoders and A/C software interfaces assume you have the AUTO function. Try purchasing from a “branded” supplier for easier access to updates. CAN bus Decoders There are two kinds of universal CAN bus decoders. You may have difficulty finding them by part number. Search for “dodge journey CAN bus” or “Android CAN bus” and you should find both. Both are typically capable of selecting between multiple CAN bus protocols. Below are part numbers and markings of CAN bus decoders I’ve seen for the Journey. RZ-JP06: Typically silver. Both connectors attach to the rear. DWS-2022-04-12: Black. Has one connector attached to the side and one on the rear. CAN bus Protocols for Dodge Journey The protocols compatible with the Dodge Journey on these head units are: Raise, OuDi, Dogen, Union, and BSJ. Raise is typically recommended for all models, but you may have better luck with OuDi prior to updating your decoder software. Reach out to your seller if features are missing or not working. Head Units Most head unit hardware and software is made by FYT or MTCD. Head units are referred to by the processor or in some cases manufacturer for those that have custom software for their units, like Mekede / DUDUAUTO. Almost all head units you purchase, branded or unbranded, run the exact same software as all the others. Focus on the specifications of the device you want. Popular resellers are Atoto, Joying, Mekede, and Navifly. 4-6GB of RAM is the minimum if you're going to be doing more than running Android Auto or CarPlay. If you're getting a unit with a higher resolution be sure it has a UIS7862, UIS7682s, or UIS7870. CPU Architecture (Compare CPUs at GadgetVersus.) CPU Description UIS7870 64bit 8-core (4x ARM Cortex-A55 @ 2.1 GHz, 3x ARM Cortex-A76 @ 2.3 GHz, 1x ARM Cortex-A76 @ 2.7 GHz, ) UIS7862s 64bit 8-core (2x ARM Cortex-A75 @ 1.8 GHz, 6x ARM Cortex-A55 @ 1.8 GHz) UIS7862 64bit 8-core (2x ARM Cortex-A75 @ 1.8 GHz, 6x ARM Cortex-A55 @ 1.8 GHz) UIS8581a 64bit 8-core (4x ARM Cortex-A55 @ 1.6 GHz, 4x ARM Cortex-A55 @ 1.2 GHz) Bezels & Fascia Search for Fiat Freemont or Dodge Journey fascia or frame and you will find one that fits. There are also fascia for the 2009-2012 Journey’s with the raised stereo on the dash. Here’s a kit from SKYFAME that includes a compatible CAN bus and cables. Pair this with a 9" or 9.5" universal head unit. Edited December 30, 2024 by Which Added link to Infotainment RE2/RB5 kit. Quote Link to comment Share on other sites More sharing options...
Which Posted December 30, 2024 Author Report Share Posted December 30, 2024 (edited) My Experience Waiting on my second android head unit to arrive after the holidays to compare, will update post then. Initial experience from eBay unit I purchased after coming across @RealFloopyGuy's review. 23 hours ago, Which said: I managed to get the steering wheel controls working after going back and forth with the seller for a while. The only outstanding issue I have with my unit is Metric vs. Imperial units on the main display. I was able to change it once but then it reverted to metric—no update on a fix for that issue yet. Other than that, my unit from the eBay seller had a misreported Android version, different screen resolution, and less cores than advertised. I'm not unhappy with it. This is apparently pretty common for these things and it's snappier than uConnect at any rate. Other Reviews Edited December 30, 2024 by Which Added initial review. Quote Link to comment Share on other sites More sharing options...
LoveTheRoadOn2Wheels Posted February 7 Report Share Posted February 7 Do you know how the unbranded OEM injectors use the AUX connection on the OEM head unit? The AliExpress write-up says “Make sure your car have Aux ctived before buying”; I’m guessing that means make sure the Aux is activated. Do these injector units play through the Aux? Do they seamlessly integrate, specifically when using the phone? Will the CD and SiriusXM still function as they do now? Thanks for the excellent post! Quote Link to comment Share on other sites More sharing options...
Which Posted February 18 Author Report Share Posted February 18 On 2/6/2025 at 7:08 PM, LoveTheRoadOn2Wheels said: Do these injector units play through the Aux? As far as I can tell, you connect it to your AUX for audio. Then any media played through Android Auto or Carplay is played through your speakers. Quote Link to comment Share on other sites More sharing options...
lucaspadua Posted March 2 Report Share Posted March 2 Great post! i’ve recently got an android head unit from ebay, but i’m having a lot of problems with it. I managed to make the climate controls kinda work but all of a sudden i have no audio at all, can’t figure out why (it worked before). does anyone have recommendations for a better head unit? (i’m assuming the one i got isn’t faulty or has crappy software) thanks 2017 Dodge journey crossroad with 8.4 Uconnect Quote Link to comment Share on other sites More sharing options...
Which Posted March 3 Author Report Share Posted March 3 13 hours ago, lucaspadua said: does anyone have recommendations for a better head unit? Currently I'm using the 512GB DUDU7 unit. It's expensive. It doesn't have everything in one place as it's going through active updates, but the interface is nice and it works. You'll want the 9.5" if you go with it. If you want a branded supplier for the generic software version of these head units try the Navifly 7862S. Before you buy anything else check the connections on the back of the head unit and your fuses. Also try resetting the canbus settings and setting it up again using RAISE > Dodge Journey settings. Quote Link to comment Share on other sites More sharing options...
lucaspadua Posted March 4 Report Share Posted March 4 Thanks for the answer! Spent all day looking at the dudu unit and i wish i knew about it sooner, bit it is considerably more than what i was planning on spending, do you have any experience/information about the dudu6? i want the 8gb version because the 360 is a nice upgrade, and i've been struggling trying to find out how to install the OEM backup camera on my journey (seems like the wiring is missing for everyone). Quote Link to comment Share on other sites More sharing options...
Which Posted March 4 Author Report Share Posted March 4 10 hours ago, lucaspadua said: do you have any experience/information about the dudu6? They've got an infographic comparing the different DUDU units. Note that if you get / want the 360 camera you need to buy from a supplier that has the 360 chip as an accessory option in their shop and add it to your cart when purchasing. Made the mistake of not doing that and don't have 360 on my unit because of it. You could add it later if you can get one of them to send it to you but it would require soldering. That's the route I'm trying to go now. 10 hours ago, lucaspadua said: i've been struggling trying to find out how to install the OEM backup camera on my journey (seems like the wiring is missing for everyone). Sometimes you luck out and the wiring you need exists in the tailgate and rear trim. You probably need to buy the harness you're missing, but it doesn't matter if you plan to replace with an aftermarket one. Quote Link to comment Share on other sites More sharing options...
