Yogitech1 Posted February 2 Report Share Posted February 2 I'm starting to get a bug now and then in the electrical system. Last week coming home I suddenly got a ding and a battery light, I looked at my voltage monitor and it read 11.9 V a little further it read 14.1 V the varied between 13.6 V and 14.3 V. Today it's been doing fine. Earlier this evening while changing hwys the car suddenly went neutral on me, engine reved, low fuel light came on, and I was reminded that I need an oil change again, which it only dies once I start it first thing. Oil is getting changed Monday. Also left tail light has been burning dim for some time but glares at you from time to time like it's possessed. Engine off key in acc. the tail light will blink randomly, (the rear wiper motor is bad), and I noticed when it blinks the rear wiper will move a bit. Does anyone have any suggestions. Other than that it runs great and nothing's wrong with the radio. P.S. The factor horn is also disconnected as it blows when it feels like it whether I'm driving it or in bed sleeping. Quote Link to comment Share on other sites More sharing options...
larryl Posted February 2 Report Share Posted February 2 Start with your battery health..... a dying battery can cause many strange symptoms 2late4u 1 Quote Link to comment Share on other sites More sharing options...
yyz Posted February 3 Report Share Posted February 3 Or alternator Quote Link to comment Share on other sites More sharing options...
Yogitech1 Posted February 3 Author Report Share Posted February 3 I found tonight that while the tail light is on (no key) the rear wiper motor turns. ??? Huh! Quote Link to comment Share on other sites More sharing options...
Dean H Posted February 3 Report Share Posted February 3 What year Journey? What engine? Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 3 Report Share Posted February 3 On 2/2/2025 at 12:15 AM, Yogitech1 said: I'm starting to get a bug now and then in the electrical system. Last week coming home I suddenly got a ding and a battery light, I looked at my voltage monitor and it read 11.9 V a little further it read 14.1 V the varied between 13.6 V and 14.3 V. Today it's been doing fine. Earlier this evening while changing hwys the car suddenly went neutral on me, engine reved, low fuel light came on, and I was reminded that I need an oil change again, which it only dies once I start it first thing. Oil is getting changed Monday. Also left tail light has been burning dim for some time but glares at you from time to time like it's possessed. Engine off key in acc. the tail light will blink randomly, (the rear wiper motor is bad), and I noticed when it blinks the rear wiper will move a bit. Does anyone have any suggestions. Other than that it runs great and nothing's wrong with the radio. P.S. The factor horn is also disconnected as it blows when it feels like it whether I'm driving it or in bed sleeping. first off you probably have broken or shorted wires in the wiring harness at the upper rear left hatchback inside the rubber boot,,,check that and that will probably fix most if not all your problems,,plus how old is your battery have it load checked and also have them check the alt to see if it is putting out the correct voltage back to the battery also corrosion under the fuse block under the hood could be a big problem as well Quote Link to comment Share on other sites More sharing options...
Yogitech1 Posted February 4 Author Report Share Posted February 4 The TIPM has been replaced twice and the ECU once. The alarm has never worked correctly as the horn blows randomly whether I'm driving the car or in bed asleep. Occasionally the car forgets the key fob, (only when locking the vehicle), and I just get in start the car and it's fine again for a while. Quote Link to comment Share on other sites More sharing options...
