Rgant_1981 Posted February 6 Report Share Posted February 6 2010 dodge journey R/T 158378 3.6L with power issues. I’ve changed the battery, the alternator 5 times last years, ignition coil for cylinder 4, spark plugs, pulled the fuse for the Bluetooth (thinking I found the problem to the battery drain), p0562 code, grounds are connected, needing 2 jumper boxes to start battery, no ticking sound but very hesitant on wanting to start this morning (as well as yesterday morning). Please help! Oh and video for what’s going on… im trying to add a video but the file is too big so there goes my proof to actually show what’s going on 😡😡😡😡 Do anyone also know if the alternator is working properly by giving the battery a charge to stay running but when I turn the truck off, it will not power back on. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted February 6 Report Share Posted February 6 (edited) NO 3.6 motor for 2010, do you mean 3.5??? A number of "drains" to cause possibilities to check out glove box light staying on. Do you have a multimeter to be able to check actual voltage at the positive and Neg points on the TIPM and strut tower? Running should get 13.5 to 14.5 volts. if OK then alternator is good. IF NOT then wiring issue between alternator and ECM{where voltage regulator is. OR a problem with the TIPM{fuse panel }circuitry itself. For good help, a lot more specific info is needed from you. EDIT: I've also heard of issues with wiring connections or even bad instrument cluster on the 08-10 DJ's. Edited February 6 by 5rebel9 larryl 1 Quote Link to comment Share on other sites More sharing options...
