wild Posted February 18 Report Share Posted February 18 Hello i have owned my journey for a little over a year now. i got in it yesterday to run to town and the abs light and service AWD light came on. the car drove fine but i was about 3 mins from home. when i got in later that day it wouldn't go over 5 mph. The traction control light has been on which is more than likely a speed sensor because my cruise control hasn't worked since then. Did it go into limp mode because of the codes? Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 20 Report Share Posted February 20 You need to have the vehicle scanned with a good scanner usually the ones the part stores has will not scan for the abs codes, with the abs /traction control lights on the cruise control will not work, I don't have AWD but I did have the traction control light and the ABS light and the brake light come on and had it scanned and the code came up 2201-c which ended up being an internal failure of the ABS electrical unit which had to be replaced however mine did NOT put my vehicle into limp mode, Google your problem or strat checking out you tube with your symptoms to see what comes up but as I said you need to have it scanned with a quality scanners that has the capability of the ABS and other service options ,,good luck and report back on what you find to be your problem/solution..and WELCOME to the group😃 Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 20 Report Share Posted February 20 you can also scan yourself using the on/off button 3 times for simple codes but that probally wont work for this problem check out you tube for that video on how to do it Quote Link to comment Share on other sites More sharing options...
