keko RT AWD Posted Tuesday at 11:26 PM Report Share Posted Tuesday at 11:26 PM Good afternoon everyone, I would like to know if someone can help me or if the same thing that is happening to me now with my Journey has happened to them. The 2 interior lights that are on the inside of the rear gate do not turn on and the lamps work, there is no voltage reaching the lamp holders, the same thing happens with the glove box lamp, I tested it outside and it works well, there is no voltage reaching the lamp holder either. And the rear window wiper stops in the place where it is and does not return to the horizontal position so as not to the rear vision. Then I started to check the fuses in the passenger compartment fuse box, which is located behind the glove box. I took them out one by one, even checking them with the tester and they were all in good condition, none were burned or cut, all in excellent working condition. I started the Dodge Journey to go do some shopping. When I got back I started checking the large main fuse box that is located inside the engine compartment. I also took one out, checked it, and if it was okay, I put it back in its corresponding place. This happened until I checked all the fuses and they all worked correctly. To my surprise, when I pressed the start button, the starter motor started to turn continuously without starting the vehicle's engine. To get the starter motor to stop turning, I had to press the start button a second time. Has anyone else had the same problem happen to them and if so, what was the problem and how do I fix it? Thank you Quote Link to comment Share on other sites More sharing options...
2late4u Posted 17 hours ago Report Share Posted 17 hours ago this has been discussed here quite frequently, 99 % your problem for the lights and wiper are due to breaking wires or shorted wires Thur the upper left rubber grommet located in the lift gate, check the forum or you can also Google on you tube to see this problem Quote Link to comment Share on other sites More sharing options...
