Electrical problems with Dodge Journey R/T AWD V6 3.6 L YEAR
Good afternoon everyone, I would like to know if someone can help me or if the same thing that is happening to me now with my Journey has happened to them. The 2 interior lights that are on the inside of the rear gate do not turn on and the lamps work, there is no voltage reaching the lamp holders, the same thing happens with the glove box lamp, I tested it outside and it works well, there is no voltage reaching the lamp holder either. And the rear window wiper stops in the place where it is and does not return to the horizontal position so as not to  the rear vision.
Then I started to check the fuses in the passenger compartment fuse box, which is located behind the glove box. I took them out one by one, even checking them with the tester and they were all in good condition, none were burned or cut, all in excellent working condition.
I started the Dodge Journey to go do some shopping. When I got back I started checking the large main fuse box that is located inside the engine compartment. I also took one out, checked it, and if it was okay, I put it back in its corresponding place. This happened until I checked all the fuses and they all worked correctly. To my surprise, when I pressed the start button, the starter motor started to turn continuously without starting the vehicle's engine. To get the starter motor to stop turning, I had to press the start button a second time.
Has anyone else had the same problem happen to them and if so, what was the problem and how do I fix it?
Thank you
this has been discussed here quite frequently, 99 % your problem for the lights and wiper are due to breaking wires or shorted wires Thur the upper left rubber grommet located in  the lift gate,  check the forum or you can also Google on you tube to see this problem
OK Thank you very much and what the glove box kight that is not turning on this wires aren{t on the left rubber goommet located in the lift gate.
could be the fuse  in the fuse box under the dash on the passenger side or the button not making the right connection
