jansengeorge Posted February 22, 2011 Report Share Posted February 22, 2011 Hi, Does anyone here knows how to replace headlight assembly?its on the passenger side..I got the replacement parts but i dont know how to replace it. Any help.. many thanks.. _______________ for BMW headlight assembly dhh3 1 Quote Link to comment Share on other sites More sharing options...
GReading Posted February 23, 2011 Report Share Posted February 23, 2011 On 2/22/2011 at 5:56 AM, jansengeorge said: Hi, Does anyone here knows how to replace headlight assembly?its on the passenger side..I got the replacement parts but i dont know how to replace it. Any help.. many thanks.. _______________ for BMW headlight assembly BULB REPLACEMENT Low Beam Headlight, High Beam Headlight, Front Turn Signal/Park Light, Side Marker Light 1. Open the hood. NOTE: It may be necessary to remove the air cleaner filter housing and position the Totally Integrated Power Module (TIPM) aside to replace certain the lights in the left headlight housing. 2. Rotate the applicable bulb and connector assembly 1⁄4 turn counterclockwise and remove the assembly from the headlight housing. 3. Disconnect the bulb from the harness connector and then connect the replacement bulb. 4. Install the bulb and connector assembly into the headlight housing and rotate it 1⁄4 turn clockwise to lock it in place. This is on page 462 of your owners manual. dhh3 1 Quote Link to comment Share on other sites More sharing options...
robertc85 Posted May 31, 2011 Report Share Posted May 31, 2011 I believe the question was in regard to the removal of the "Headlight Assembly" not the bulbs. I too require an answer to the question. I purchased a replacement headlight assembly and started removing the '3' screws securing the headlight. Then I discovered the grill was in the way, the grill is attached to the bumber, so I am led to believe the whole front bumper has to be removed to replace the headlight (which sucks) Can someone confirm this ? Please tell me there is an easier way to remove the headlight assembly. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Maxbarnak Posted October 16, 2011 Report Share Posted October 16, 2011 I think like you, Could you please confirm if you needed remove the front bumper for install or remove the headlight, thanks dhh3 1 Quote Link to comment Share on other sites More sharing options...
Goaltender Posted October 16, 2011 Report Share Posted October 16, 2011 (edited) 1.Disconnect and isolate the battery negative cable .2.Loosen the front fascia on the same side of the vehicle as the front lamp unit being removed. 3.Remove the four plastic push-pin fasteners that secure the upper grille to the Front End Module (FEM). 4.Flex the fascia and grille (1) outward far enough to access and remove the three screws (2) that secure the front lamp unit to the FEM. 5.Pull the front lamp unit away from the FEM far enough to access and disconnect the headlamp and dash wire harness connectors from the back of the lamp housing. 6.Remove the front lamp unit from the vehicle. Edited October 16, 2011 by Goaltender dhh3 1 Quote Link to comment Share on other sites More sharing options...
flipsyd Posted March 31, 2013 Report Share Posted March 31, 2013 I have a dodge journey 2013... I think the headlight assembly is the same. Do you have to remove the front bumper? dhh3 1 Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted April 1, 2013 Report Share Posted April 1, 2013 No...if you read the post above yours instruction #4 iswhat you need to do without removing the bumper. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Mark Reimer Posted May 8, 2013 Report Share Posted May 8, 2013 where did you guy get your replacement headlights? dhh3 1 Quote Link to comment Share on other sites More sharing options...
nerner Posted May 25, 2013 Report Share Posted May 25, 2013 On 5/8/2013 at 4:09 AM, Mark Reimer said: where did you guy get your replacement headlights? Try partshub.ca dhh3 1 Quote Link to comment Share on other sites More sharing options...
mgdj06 Posted August 28, 2015 Report Share Posted August 28, 2015 On 10/16/2011 at 11:44 AM, Goaltender said: 1.Disconnect and isolate the battery negative cable .2.Loosen the front fascia on the same side of the vehicle as the front lamp unit being removed. 3.Remove the four plastic push-pin fasteners that secure the upper grille to the Front End Module (FEM). 4.Flex the fascia and grille (1) outward far enough to access and remove the three screws (2) that secure the front lamp unit to the FEM. 5.Pull the front lamp unit away from the FEM far enough to access and disconnect the headlamp and dash wire harness connectors from the back of the lamp housing. 6.Remove the front lamp unit from the vehicle. I know this is almost 4 yr old thread but Im still confsed on how to take off the headlight assembly, thus the instruction above also applies to 2015 dj sxt. Thanks if someone can still read this and help me. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted August 31, 2015 Report Share Posted August 31, 2015 These instructions still apply. What exactly are you confused about? That may help get you better answers. dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
mgdj06 Posted September 14, 2015 Report Share Posted September 14, 2015 On 8/31/2015 at 2:47 PM, Lobitz68 said: These instructions still apply. What exactly are you confused about? That may help get you better answers. Its all good, my only question now is how to baked open, i already read some thread regarding baking the headlight just dont want to mess things up since this is my first time doing this. Im noob with this kind of thing but i can disassemble and put back anything as low ng as there is detailed instruction. I alread plastidip my grill, whats left to paint are the headlight and side mirrors so much dj would look like i have the blacktop. dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted September 15, 2015 Report Share Posted September 15, 2015 Why didn't you just buy a blacktop.... Lol dhh3 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted September 15, 2015 Report Share Posted September 15, 2015 On 9/14/2015 at 11:54 PM, mgdj06 said: Its all good, my only question now is how to baked open, i already read some thread regarding baking the headlight just dont want to mess things up since this is my first time doing this. Im noob with this kind of thing but i can disassemble and put back anything as low ng as there is detailed instruction. I alread plastidip my grill, whats left to paint are the headlight and side mirrors so much dj would look like i have the blacktop. Dodge uses a sealant referred to as Permaseal and it is difficult to work with. Unless the instructions you referred to were speaking to this type of sealant, I would disregard the temps and times given. For Permaseal use a temp of 285 degrees (F) and let them sit in the preheated oven for at least 23 minutes. From there, the other instructions are likely right on. With perma seal you may need to occasionally reheat the headlight while you are working with it, as the assembly will come apart much more slowly. Take your time so you don't wreck your headlight. Here is a good video of the process... dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted September 15, 2015 Report Share Posted September 15, 2015 FYI. There is a Blacktop headlight assembly, for the left side, on the Forum, in the Parts for Sale section. Quote Link to comment Share on other sites More sharing options...
Captain Marty Posted August 15, 2016 Report Share Posted August 15, 2016 Okay, I am replacing my headlight assemblies on my Journey. I have read the instructions above twice, pulled out my front grill and undone the three screws, step 4. Step 5, disconnect the wires. Step 6 says to "Remove the front lamp unit from vehicle" That is a nice easy instruction, but it does not say how to remove it? Remove from inside the engine compartment or pull straight out the front? It will not come straight out the front since the lamp in larger than the opening? It hits on the top and on the bottom bumper. There is a video out there that says it removes the assemblies, but does not show taking the headlights out of the car, it only shows them after the new ones are installed. Anyone out there actually do this yet?? Replace their headlight assembly on a dodge Journey? Looks to me either you have to bend he hell out of your bumper or take the bumper off? Thanks for any further instruction. Best regards, Marty dhh3 1 Quote Link to comment Share on other sites More sharing options...
buckshot7526 Posted August 16, 2016 Report Share Posted August 16, 2016 (edited) I just replaced my headlight assemblies and I did have to pull on the bumper to get them out. I did put a thin layer of tape on the bumper so it didn't get scratched, it does take some patience to get them out but they will come out. You will notice my headlights don't seem too bright but they are actually brighter than my OEM headlights. I did change the bulbs to the Sylvania zXe bulbs because the ones that came with it were not too bright. Also the amber light bar comes on only for the turn signals, I just had my hazards on at the time to show them working. Edited August 16, 2016 by buckshot7526 2016Redline and dhh3 2 Quote Link to comment Share on other sites More sharing options...
Captain Marty Posted August 16, 2016 Report Share Posted August 16, 2016 Hello, thanks for your response, those are the same lights I just bought. and you are saying the bulbs weren't bright enough? I thought they were the projector bulbs and would be plenty bright? Maybe I should change the bulbs as well before installing. And I figured the led were just the turn signals. dhh3 1 Quote Link to comment Share on other sites More sharing options...
buckshot7526 Posted August 17, 2016 Report Share Posted August 17, 2016 (edited) On 8/16/2016 at 4:31 PM, Captain Marty said: Hello, thanks for your response, those are the same lights I just bought. and you are saying the bulbs weren't bright enough? I thought they were the projector bulbs and would be plenty bright? Maybe I should change the bulbs as well before installing. And I figured the led were just the turn signals. Expand Hello, when I matched the bulbs that came with it they have the yellow color to them and when I changed to the Sylvania zXe bulbs I had a much clearer white light. The bulbs that come with them are made by AU-lite which I never heard of, also once installed you will need to do the adjustment to level you headlights out. You can find the bulbs on amazon much cheaper, you will need to get the H7 low beams and H1 high beams if you do change them. Edited August 17, 2016 by buckshot7526 dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted August 17, 2016 Report Share Posted August 17, 2016 FYI These are halogen projectors, not HID projectors. I just replaced my bulbs with zXes. Seller had "make offer" on ebay and I got them for $32 a pair. Package says lifetime of these bulbs are not as long as regular halogens. But, they are much brighter in my stock Crossroad housings with the inside painted black. Time will tell. buckshot7526 1 Quote Link to comment Share on other sites More sharing options...
