Matthias Illenseer Posted February 24, 2011 Report Share Posted February 24, 2011 Hi. I'm from Canada and I want to install HIDs on my high beams. I was wondering if there was any way for me to disable my DRLs. thanks! Quote Link to comment Share on other sites More sharing options...
Jerith Posted February 28, 2011 Report Share Posted February 28, 2011 No idea's here, sorry. Quote Link to comment Share on other sites More sharing options...
OhareFred Posted March 1, 2011 Report Share Posted March 1, 2011 Hi. I'm from Canada and I want to install HIDs on my high beams. I was wondering if there was any way for me to disable my DRLs. thanks! Aren't DRL's a required item in Canada? It's not here in the States, but I thought they were mandatory up North, but I could be wrong. If they are required, no dealer will disconnect them. You might be out of luck. Quote Link to comment Share on other sites More sharing options...
scoe54 Posted March 1, 2011 Report Share Posted March 1, 2011 I haven't checked on the Journey, but on other cars I've had the DRL would go off when the parking brake is applied. If its the same on the Journey, then there's probably some wires on a switch at the parking brake pedal that you could connect to shut the lights off. However, I think the previous poster is correct, DRL's are required in Canada. Quote Link to comment Share on other sites More sharing options...
Matthias Illenseer Posted March 2, 2011 Author Report Share Posted March 2, 2011 thanks for all the replies. I know that they are required in Canada. I'm planning on putting the DRLs on the fog lights. I don't like them on the high beams due to not being able to put HIDs on the highs because I would blind everyone on the road during the day. But I'd like the brightness of the high beam HID at night on the highway since I drive a lot at night. That brake thing might be worth looking into, thanks Quote Link to comment Share on other sites More sharing options...
OhareFred Posted March 4, 2011 Report Share Posted March 4, 2011 thanks for all the replies. I know that they are required in Canada. I'm planning on putting the DRLs on the fog lights. I don't like them on the high beams due to not being able to put HIDs on the highs because I would blind everyone on the road during the day. But I'd like the brightness of the high beam HID at night on the highway since I drive a lot at night. That brake thing might be worth looking into, thanks AHHHH, thats another story! I had a Chevy with DRL's and yes, if you pushed the parking brake on, then took it off AFTER the engine had started the drl's would stay off till the next restart. Maybe you could wire in a momentary contact switch in the parking brake switch wiring. At least then all you would have to do is flip the switch. I have seen discussions on this site about HID lighting and turning fogs into DRL's in the past. I can't recall in what section though. Anybody remember??? Good luck! Quote Link to comment Share on other sites More sharing options...
Matthias Illenseer Posted March 7, 2011 Author Report Share Posted March 7, 2011 AHHHH, thats another story! I had a Chevy with DRL's and yes, if you pushed the parking brake on, then took it off AFTER the engine had started the drl's would stay off till the next restart. Maybe you could wire in a momentary contact switch in the parking brake switch wiring. At least then all you would have to do is flip the switch. I have seen discussions on this site about HID lighting and turning fogs into DRL's in the past. I can't recall in what section though. Anybody remember??? Good luck! Well I always use my parking brake so I always have the parking brake applied when the car is off and when the car turns on the DRLs come on anyways :s Quote Link to comment Share on other sites More sharing options...
Matthias Illenseer Posted March 23, 2011 Author Report Share Posted March 23, 2011 Maybe I will just put black electrical tape over the light sensor on the dash so then my DRLs won't turn on Can't get anything else to work Quote Link to comment Share on other sites More sharing options...
FleshWound Posted March 23, 2011 Report Share Posted March 23, 2011 I'm sure the dealership can turn them off. They'll most likely charge you an hour's worth of labour though. I personnaly don't think your HID bulbs would blind any oncoming traffic as it would be daytime, and you can always turn your low-beams on if you think the HIDs are anoying anyone. the DRL use much less power than you normal low-beams so HID used as your DRL should still be less powerful than your standard low-beams. hope this helps, keep us in the loop Quote Link to comment Share on other sites More sharing options...
Matthias Illenseer Posted March 23, 2011 Author Report Share Posted March 23, 2011 I'm sure the dealership can turn them off. They'll most likely charge you an hour's worth of labour though. I personnaly don't think your HID bulbs would blind any oncoming traffic as it would be daytime, and you can always turn your low-beams on if you think the HIDs are anoying anyone. the DRL use much less power than you normal low-beams so HID used as your DRL should still be less powerful than your standard low-beams. hope this helps, keep us in the loop HID's do not work on DRLs because of the lower power as HIDs require a constant 12v. Which requires me to get a relay harness to take power directly from the battery resulting in blinding high beams during the day Quote Link to comment Share on other sites More sharing options...
Matthias Illenseer Posted April 12, 2011 Author Report Share Posted April 12, 2011 The only thing I figured out to make the DRLs turn off is if I take the light sensor out and then leave my lights on auto. That way the low beams are always on and the DRLs don't turn on. Quote Link to comment Share on other sites More sharing options...
