Flickering lights
Goats
Last week on the way to a NHL hockey game ive noticed all the lights and headlights flicker.Also sometimes the truck goes dead while trying to start it and now the pass rear door lock jumps up and down real fast a couple times while u try to lock it. When do the issues stop and the truck only has about 2200 miles.
Almost sounds like a bad or loose ground, either right at the battery or at the main distribution box. I'd have the dealer check it before you get stranded! Good Luck.
yea i was thinking the samething and it would go with the weird no power start issue as well even thought the battery was replaced already cause they thought it was the battery
