brbarker88 Posted March 16, 2011 Report Share Posted March 16, 2011 i tryred to disable the alarm but can not do it can anyone help please Quote Link to comment Share on other sites More sharing options...
Windancer Posted March 17, 2011 Report Share Posted March 17, 2011 i tryred to disable the alarm but can not do it can anyone help please Just out of curiousity, Why would you want to do it? Terry Quote Link to comment Share on other sites More sharing options...
Matthias Illenseer Posted March 17, 2011 Report Share Posted March 17, 2011 This worked for me: 1. With all doors closed, and the ignition switch in any position except ON or START, buckle the driver’s seat belt. 2. Turn the ignition switch to the ON position, (engine does not need to be running). Wait for the Seat Belt Reminder Light to turn off and then proceed to the next step. NOTE: You must perform the following steps within 60 seconds of turning the ignition switch to the ON position. 3. Unbuckle the driver’s seat belt, allow the seat belt to retract, and then re-buckle the driver’s seat belt at least three times, ending with the seat belt buckled. NOTE: Watch for the Seat Belt Reminder Light to turn on while the seat belt retracts and turn off while rebuckling the seat belt. It may be necessary to completely retract the seat belt each time. 4. Turn the ignition switch to the LOCK position. A single chime will sound to signify that you have successfully completed the programming. The BeltAlert?? can be reactivated by repeating this procedure. NOTE: When the BeltAlert?? is deactivated, the Seat Belt Reminder Light will continue to illuminate as long as the driver’s seat belt is unbuckled/retracted. Quote Link to comment Share on other sites More sharing options...
brbarker88 Posted March 17, 2011 Author Report Share Posted March 17, 2011 ok thanks i will try it Quote Link to comment Share on other sites More sharing options...
