rlwarner78 Posted March 22, 2011 Report Share Posted March 22, 2011 I have a 2011 journey crew with the media center 640 radio. I have used the USB port to hook up my ipod and it works great, I also have a 500GB external hp pocket drive hard drive with 45,000 songs. When i plug that in nothing happens? Any ideas? Quote Link to comment Share on other sites More sharing options...
drb227 Posted March 22, 2011 Report Share Posted March 22, 2011 If there is a power light on the drive, does it light up when you plug it in? Could be that the USB port doesn't have enough power to power a hard drive. Quote Link to comment Share on other sites More sharing options...
rlwarner78 Posted March 28, 2011 Author Report Share Posted March 28, 2011 If there is a power light on the drive, does it light up when you plug it in? Could be that the USB port doesn't have enough power to power a hard drive. That may be the case. I wonder if a harddrive with a seperate power source would work? Quote Link to comment Share on other sites More sharing options...
UPMedic Posted March 30, 2011 Report Share Posted March 30, 2011 It's also possible that it isn't set up to recognize that large of a size. I've read about some systems having maximum amount of gig's they're able to read... <shrug> I have a 1 TB external hard drive that connects via USB and has it's own power supply... Hmmm.... I should try it sometime. Then again, I have the 8.4n, so, not sure if that makes a difference, too. Quote Link to comment Share on other sites More sharing options...
SaskGuy Posted March 30, 2011 Report Share Posted March 30, 2011 This is only an assumption on my part, but.... Maybe the hard drive would have to be reformatted as a FAT32 file type??? I had to do that with an external hard drive that I hooked up to my PS3.. Quote Link to comment Share on other sites More sharing options...
