chiefgarymac Posted March 28, 2011 Report Share Posted March 28, 2011 Anyone know how to not have driver seat heat start up as default every time? Quote Link to comment Share on other sites More sharing options...
drozz Posted March 28, 2011 Report Share Posted March 28, 2011 Anyone know how to not have driver seat heat start up as default every time? You have to go into the settings on your touch screen, and i believe it is under engine startup, you can uncheck it so it doesn't happen. Quote Link to comment Share on other sites More sharing options...
drb227 Posted March 29, 2011 Report Share Posted March 29, 2011 Do the following: 1. Click the More button in the lower right corner. 2. Click the Settings button. 3. Click on the option "Auto-On Comfort & Remote Start" 4. Remove the check mark from "Auto-on Driver Heated/Vented Seat & Steering Wheel with Vehicle Start" Note that I sometimes have to press the box a few times before the check mark will disappear. I also do this with the ignition in the Run setting (vehicle not on) Quote Link to comment Share on other sites More sharing options...
Windancer Posted March 29, 2011 Report Share Posted March 29, 2011 Anyone know how to not have driver seat heat start up as default every time? Wish I had that option on my 2010. terry Quote Link to comment Share on other sites More sharing options...
UPMedic Posted March 30, 2011 Report Share Posted March 30, 2011 4. Remove the check mark from "Auto-on Driver Heated/Vented Seat & Steering Wheel with Vehicle Start" Note that I sometimes have to press the box a few times before the check mark will disappear. I also do this with the ignition in the Run setting (vehicle not on) Funny you mention that you had to hit the box a few times...so did I - enough that I thought it was strange! I'm pretty sure I read somewhere, too, that the heated seat (if set to automatically come on), only comes on automatically if the outside temp is below a certain value (don't remember what temp it was...) Quote Link to comment Share on other sites More sharing options...
hereticj Posted April 5, 2011 Report Share Posted April 5, 2011 (edited) I think if you have the temperature set to LOW before you shut the vehicle off, they will not come on automatically when its started back up. EDIT: I was wrong about that. I just got in to mine with the temp at 21 degrees, not low, and the seats didnt come on. I can only assume its based on the outside temperature. Edited April 6, 2011 by hereticj Quote Link to comment Share on other sites More sharing options...
