Look Here for MyGIG Software/Firmware Updates...
Hey all. While nosing around for information on the MyGIG player we all have in our Journeys, I stumbled upon this site:
http://mofv.com/mygig/
It hosts software/firmware updates for every MyGIG system in existence. It also contains up to date GRACENOTE databases for the MyGIG system. There is a section for the Journey MyGig system, but as of yet there is not software/firmware for it. It does say it will be up shortly though. There is, however, an update for the GRACENOTE music database used when ripping CD's to your hard drive.
Neither I, nor this forum, are affiliated with the above site. So be cautious when updating your MyGig, as there is always the possibility you could brick it. However, the nice thing aobut the site listed above is that it shows step by step PICTURES of what to do and what you will see on the MyGIG screen during each step of the update process.
Good Luck,
Xphyle
Thanks for the link!
The Gracenote updates are particularly handy.
Important note: Match the firmware (software, technically, since it's stored on a HDD) radio type with your radio type, which is the three letter code usually found on the lower right corner of the radio faceplate, usually something like RER, REN, REU, etc. depending on your model.
  • 3 months later...
Hey guys, I have tried and tried to connect to the link and it will not connect. anyone have any ideas?
  • 5 years later...
Hello All
I was able to reverse lookup the HDD password of MyGig RHB(430N) and RBZ(430)
I would call this read between the lines ... not hacking...
Seems like the Dodge Jeep Chrysler RBZ RHB uconnect Mygig (Made by Mitsubishi) and Mitsubishi Multi-Communication System (MMCS) share some common bases
Thanks to the following thread:
HDD unlocking on the Mitsubishi Multi-Communication System (MMCS HDD unlock)
quite a lot of work and efforts; but thanks a lot to brian360!
Embedded in Main_APL_CPU0.mbi :
Binary "RAW" password :
1) B2BAB3BCB0DFACBEB1BBBEDFADBDA5DFBE8A9B9690DFAA8C9A8DDFDFDFDFDFDF
2) B2BAB3BCB0DFACBEB1BBBEDFB2BEACBCDFAF8D909B8A9C8B8CDFB29E8C8B9A8D
3) B2BAB3BCB0DFACBEB1BBBEDFADBDA5DFBE8A9B9690DFB29E8C8B9A8DDFDFDFDF (RBZ Only - SWDL_CPU0.mbi)
MSB of each byte is high. Invert all of the 8 bits sequences of the password you get this
1) 4D454C434F2053414E44412052425A20417564696F2055736572202020202020
2) 4D454C434F2053414E4441204D4153432050726F6475637473204D6173746572
3) 4D454C434F2053414E44412052425A20417564696F204D617374657220202020 (RBZ Only - SWDL_CPU0.mbi)
ASCII:
1) "MELCO SANDA RBZ Audio User "
2) "MELCO SANDA MASC Products Master"
3) "MELCO SANDA RBZ Audio Master " (RBZ Only - SWDL_CPU0.mbi)
MELCO - Mitsubishi Electronics Company
SANDA - the company's Sanda Works facility
Would anyone know if there is a way to recover the mygig unit lock in a keeps rebooting uconnect logo ?
Would anyone know where is the bit do de-activate in motion protection for DVD and nav lock ?
Thanks in advance!
