Stretch Posted April 21, 2011 Report Share Posted April 21, 2011 I called the dealer and explained that the EVIC would default to mpg and would like it to save to L/100Km and also when I used the remote start the engine would run for a few seconds and then shut down and the EVIC said the remote start function was disabled. . .took it to the dealer and had it flashed (update) which fixed the problems. However when I went to drive off the dealer lot the engine light came on so I left it and borrowed a loaner. Will add an update next day. Quote Link to comment Share on other sites More sharing options...
drb227 Posted April 21, 2011 Report Share Posted April 21, 2011 (edited) Just curious - do you know what the update was that they applied? I am wondering if it is the same update that we've been discussing in this thread: Edited April 21, 2011 by drb227 Quote Link to comment Share on other sites More sharing options...
Stretch Posted April 21, 2011 Author Report Share Posted April 21, 2011 No I don't but I could check . . .won't be until Monday or Tuesday tho. apparently the engine fault I experienced is the result of something called a cam phaser which needs to be ordered and replaced, so won't see dealer or my Journey until then. Dealers should be able to the update. . . Quote Link to comment Share on other sites More sharing options...
geurny2011 Posted April 21, 2011 Report Share Posted April 21, 2011 I believe someone mentioned something about this in an earlier post > Flash Update :" Garbled Text that May Appear On The Screen " Quote Link to comment Share on other sites More sharing options...
