resetting UConnect 8.4N system
Hi, does anybody know how to reset the Uconnect 8.4 system?
I read on some other forums that I just need to remove the IOD (ignition off-draw) fuse for a couple minutes. But I don't know where is that fuse even after looking carefully on both fuse box.
BTW i need to do that to try to fix my Bluetooth & VR system that suddenly stopped working.
This is the fuses according to the manual. I took a look and didnt see any called that but you might as well check it out.
Fuse Name and Loaction
I have found another UserManual on the ChryslerCanada website :
http://www.chryslercanada.ca/owners/en/manuals/2011/2011%20JC%20Journey.pdf
This one clearly refers to the IOD Fuse, but doesn't say which one it is.
On page 379 it says :
VEHICLE STORAGE
If you will not be using your vehicle for
more than 21 days you may want to take
steps to preserve your battery. You may:
• Remove the IOD (Ignition Off-Draw)
mini-fuses from the Totally Integrated
Power Module located in the engine
compartment.
• Or, disconnect the battery negative
cable.
