money0309 Posted June 26, 2011 Report Share Posted June 26, 2011 I have a 2011 Journey Mainstreet that was bought brand new and just hit 5000 miles. I'm having some issues and wondering if anyone else has had similar problems. The first thing I noticed is that at times the car has a rough idle and the idle also sticks at roughly 1000 - 1100 rpms which is enough to pull the car forward while coming to a stop. The next and most annoying thing is when I turn on my left turn signal my windshield wipers make one pass and cut off. The wipers do the same thing after a right turn when the signal arm returns to the off position. It seems to do it more on hotter days also. My wife took the car to the dealership while I was working but they basically blew her off and said everything was fine and normal so I will be taking it back myself when I have the time. Just wondering if others have had similar experiences. Quote Link to comment Share on other sites More sharing options...
Armendegga Posted June 26, 2011 Report Share Posted June 26, 2011 The windshield wiper turning on when you are using your turn signal definitely seems to indicate a short/loose wire or something. That alone should be proof to the dealer that they should check out what's going on... I would recommend showing them the behavior that you are seeing. It would be pretty hard to blow off if they can see what's going on. Quote Link to comment Share on other sites More sharing options...
DJ11 Posted June 28, 2011 Report Share Posted June 28, 2011 I have a 2011 Journey Mainstreet that was bought brand new and just hit 5000 miles. I'm having some issues and wondering if anyone else has had similar problems. The first thing I noticed is that at times the car has a rough idle and the idle also sticks at roughly 1000 - 1100 rpms which is enough to pull the car forward while coming to a stop. The next and most annoying thing is when I turn on my left turn signal my windshield wipers make one pass and cut off. The wipers do the same thing after a right turn when the signal arm returns to the off position. It seems to do it more on hotter days also. My wife took the car to the dealership while I was working but they basically blew her off and said everything was fine and normal so I will be taking it back myself when I have the time. Just wondering if others have had similar experiences. I had this same problem with a 2007 Charger. I can't remember exactly what had to be replaced but it was something electrical and it was covered under warranty. Don't let your dealer blow you off! Sorry I don't have more information, but I hope this helps! Quote Link to comment Share on other sites More sharing options...
