20journey11 Posted July 2, 2011 Report Share Posted July 2, 2011 I lost all sound from my screen. Everything on the 8.4 screen works,but no sound. No radio, CD, Bluetooth, Navigation, back up sensors. It is going in the shop wednesday to try and figure out what is happening. Anybody have any insight to this? Bbabb 1 Quote Link to comment Share on other sites More sharing options...
Derekmclain9 Posted July 26, 2011 Report Share Posted July 26, 2011 Did you ever find out what was causing this issue mine sems to be doing the same thing. I am assuming it has something to do with the amp. Quote Link to comment Share on other sites More sharing options...
20journey11 Posted July 26, 2011 Author Report Share Posted July 26, 2011 Did you ever find out what was causing this issue mine sems to be doing the same thing. I am assuming it has something to do with the amp. [/quote Took it to the Dodge dealer and they told me the amp was locked up. They hooked it to the computer and fixed it. The service tech said they have seen it a couple times in the 2011's. Haven't had anymore problems it. Quote Link to comment Share on other sites More sharing options...
Derekmclain9 Posted July 27, 2011 Report Share Posted July 27, 2011 yeah i called today and they said they are pretty sure the is a tsb or recall on the alpine system for this reason. Quote Link to comment Share on other sites More sharing options...
groale Posted August 13, 2011 Report Share Posted August 13, 2011 This just happened to me today, ad while I'm on vacation. Can anyone tell me if it's a quick reset? I could bring it to a local dealer here in Scottsdale. Only have 3000 miles on it and have to drive across the desert in two days. No music will suck, and make me very annoyed. Where is the amp? Can I reset it?? Thx Quote Link to comment Share on other sites More sharing options...
Derekmclain9 Posted August 13, 2011 Report Share Posted August 13, 2011 (edited) on my work order they said that you can pull the fuse out and put it back in and that resets it and should be a quick fix but i dont know where the fusebox inside the vehicle is cause thats where the fuse for the amp is. So if you find it let me know please because they left the cover off mine and i would like to know anyways incase it happens again. . Edited August 13, 2011 by Derekmclain9 Quote Link to comment Share on other sites More sharing options...
mrlux Posted August 13, 2011 Report Share Posted August 13, 2011 on my work order they said that you can pull the fuse out and put it back in and that resets it and should be a quick fix but i dont know where the fusebox inside the vehicle is cause thats where the fuse for the amp is. So if you find it let me know please because they left the cover off mine and i would like to know anyways incase it happens again. . From what I have heard all the fuses are under the hood. Check out the owners manual. Quote Link to comment Share on other sites More sharing options...
groale Posted August 13, 2011 Report Share Posted August 13, 2011 As soon as I finish my margarita at the pool I'll go look and let you know! Thx Quote Link to comment Share on other sites More sharing options...
20journey11 Posted August 13, 2011 Author Report Share Posted August 13, 2011 This just happened to me today, ad while I'm on vacation. Can anyone tell me if it's a quick reset? I could bring it to a local dealer here in Scottsdale. Only have 3000 miles on it and have to drive across the desert in two days. No music will suck, and make me very annoyed. Where is the amp? Can I reset it?? Thx Took about 20 minutes for the service department to fix it. The amp is under the front passenger seat. Quote Link to comment Share on other sites More sharing options...
b1pig Posted August 13, 2011 Report Share Posted August 13, 2011 just out of curiosity.... is this problem specific to the alpine system, or the "base" system, too? Quote Link to comment Share on other sites More sharing options...
Powdered Toast Man Posted August 13, 2011 Report Share Posted August 13, 2011 There is a "rapid response" fix for several Dodge vehicles with the sound system with the amp. The dealers are supposed to fix this before customers take delivery and it applies to models before May 2011. I had mine in for an oil change and the dealer ended up replacing the amp due to the TSB and I hadn't even had any problems. The Rapid Response code is RRT 11-066. Quote Link to comment Share on other sites More sharing options...
groale Posted August 13, 2011 Report Share Posted August 13, 2011 I found the amp, and unplugged the two plugs on the side and then reinserted. It worked, all sounds have returned. I am still going to bring it in and ask about the RRT when I get home as I don't want to be doing this for the next five years. Thx 19InBlkJrny 1 Quote Link to comment Share on other sites More sharing options...
19InBlkJrny Posted August 15, 2011 Report Share Posted August 15, 2011 Where did you locate the amp? Quote Link to comment Share on other sites More sharing options...
Armendegga Posted August 15, 2011 Report Share Posted August 15, 2011 The amp is underneath the front passenger seat. Quote Link to comment Share on other sites More sharing options...
cottontop Posted August 23, 2011 Report Share Posted August 23, 2011 on my work order they said that you can pull the fuse out and put it back in and that resets it and should be a quick fix but i dont know where the fusebox inside the vehicle is cause thats where the fuse for the amp is. So if you find it let me know please because they left the cover off mine and i would like to know anyways incase it happens again. . I just tried it and it worked. The fuse box is under the glove box on the right side (not easy access) but it did work. Quote Link to comment Share on other sites More sharing options...
bjthebasstracker Posted October 31, 2012 Report Share Posted October 31, 2012 happened to me today, reset the AMP under the passenger seat, thanks ! Quote Link to comment Share on other sites More sharing options...
mrlux Posted November 16, 2012 Report Share Posted November 16, 2012 Taking my 2011 Lux in tomorrow for the same problem. tried to unhook the amp but could only get one plug loose. Dodn't want to break something and then have the dealer say the warranty was void. It is still under warranty so let them fix it. Quote Link to comment Share on other sites More sharing options...
mrlux Posted November 17, 2012 Report Share Posted November 17, 2012 Here is what the dealer did. Performed capacitive discharge and updated amplifier software. While there they did two other RRTs. 11-078, reprogrammed cabin compartment module, 11-082,reprogrammed body control module. I had the BCM reprogrammed about a year ago but the service writer said this was an update for the starting issues(dead battery). Quote Link to comment Share on other sites More sharing options...
AstralRT Posted November 29, 2012 Report Share Posted November 29, 2012 Is this relative to the 2012 8.4n system as well? This exact thing happened to me tonight. Everything is working except audio. Even the audio settings under "more" is disabled. Planning on calling the dealer in the morning and taking a look myself, but was sure how relatives the systems are. Bbabb 1 Quote Link to comment Share on other sites More sharing options...
AstralRT Posted November 30, 2012 Report Share Posted November 30, 2012 So I just tried removing the fuse and also the amp wires, didn't work. Calling the dealership in the morning. Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted November 30, 2012 Official Dodge Support Report Share Posted November 30, 2012 Is this relative to the 2012 8.4n system as well? This exact thing happened to me tonight. Everything is working except audio. Even the audio settings under "more" is disabled. Planning on calling the dealer in the morning and taking a look myself, but was sure how relatives the systems are. Astra, I found this that may apply to the issue you are experiencing. NUMBER: 08-032-12 REV. A GROUP: Electrical DATE: November 20, 2012 SUBJECT: Flash: No Audio From The Radio Caused By The Amplifier Not Communicating OVERVIEW: This bulletin involves re-flashing the Amplifier with updated software. MODELS: 2011 - 2012 (JC) Journey 2011 - 2012 (LD) Charger 2011 - 2012 (LX) 300 NOTE: **This bulletin applies to JC vehicles equipped with 368 Watt Amplifier (sales code RD6)**. NOTE: **This bulletin applies to LD, LX vehicles equipped with 276 Watt Amplifier (sales code RD7) or 506 Watt Amplifier (sales code RFD) or 552 Watt amplifier (saels code RDS)**. SYMPTOM/CONDITION: The customer may indicate that there is no audio and/or radio is muted. This condition may be caused by the amplifier not communicating on the bus. Flashing the amplifier will correct this condition. okibcn 1 Quote Link to comment Share on other sites More sharing options...
AstralRT Posted November 30, 2012 Report Share Posted November 30, 2012 So I'm not sure what happened, but not long after I tried pulling the fuse and amp wires, the audio started working again.....but not right away. Between the time I pulled the fuse and amp wires there was some short driving, a few restarts and some more short driving, at the end of it I gave up and was just parked waiting for someone I had already tried about 5 minutes before and the audio didn't work, but I decided once more and it suddenly worked and has been working perfectly since. I assume the fuse and amp wires had some affect, but because it didn't have a positive affect right away I'm not sure what else might have contributed to the resolve. So as of now everything is working and I'll be keeping an eye on it, I am scared to turn off the audio right now though just incase Thanks for the helpl Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCACares Posted December 3, 2012 Official Dodge Support Report Share Posted December 3, 2012 Astral, Got your PM, just happy you were able to get it working agin. I highly recomend getting your DJ into your dealer if/when it happens again. I would hate to see this become an ongoing issue for you. PM if it you require my assistance and have a great day! Quote Link to comment Share on other sites More sharing options...
LUX MAN Posted December 6, 2012 Report Share Posted December 6, 2012 This just happened to my wife today. After reading this, I unplugged and replugged the Amp and it worked. But I will take it in next week for the Software updates. Thanks for the info and for putting your results on the forum. Quote Link to comment Share on other sites More sharing options...
okibcn Posted March 19, 2013 Report Share Posted March 19, 2013 Same problem here... I can do the workaround but I prefer to go to the dealer and have the firmware updated. Regards Quote Link to comment Share on other sites More sharing options...
