MazdaspeedR6 Posted July 2, 2011 Report Share Posted July 2, 2011 Does anybody know what Dodge OEM rims will fit on the Journey? Quote Link to comment Share on other sites More sharing options...
Armendegga Posted July 4, 2011 Report Share Posted July 4, 2011 I believe drb227 mentioned that newer model Grand Caravan 16's will fit on the Journey... The bolt pattern is 5x127. Quote Link to comment Share on other sites More sharing options...
Appalachian Journey Posted July 4, 2011 Report Share Posted July 4, 2011 I believe only the Grand Caravan currently shares the same bolt pattern. Quote Link to comment Share on other sites More sharing options...
drb227 Posted July 4, 2011 Report Share Posted July 4, 2011 In addition to the Grand Caravan, there is also, of course, the original Journey OEM 16" rims that comes on the CVP model in Canada. I don't know if they are EXACTLY the same or not. Quote Link to comment Share on other sites More sharing options...
humansoul Posted July 4, 2011 Report Share Posted July 4, 2011 I believe you can also fit Jeep Wrangler rims...they too are 5x127 Quote Link to comment Share on other sites More sharing options...
rickyman2009 Posted July 5, 2011 Report Share Posted July 5, 2011 FYI............... the newer VW Routan should also fit, its made by Dodge too Quote Link to comment Share on other sites More sharing options...
Appalachian Journey Posted July 6, 2011 Report Share Posted July 6, 2011 Didn't mean to repeat info. I must have been typing as Armendegga was posting. Quote Link to comment Share on other sites More sharing options...
coolram62 Posted August 10, 2011 Report Share Posted August 10, 2011 (edited) Another vehicle to consider is the 2011 Durango. I was surprised to find they have the same 5X127 bolt pattern and the base wheel is 18X8 with a 56.4mm positive offset. I found a set on Ebay and will post results/pictures once I have them on my Journey. I'm going with a 235/55-18 as it's very close to the 225/65-17 diamater and clearance shouldn't be a problem with width. This also opens up the possibilty of factory 20" wheels if someone wanted to go that route. I posted this in another thread and apologise for the additonal post. It actually fits better here than the other. EDIT: The Durango wheels mentioned will bolt up with no interference on the rear. However the difference in offset and thicker wheel hub contacts the caliper and would also have an issue in lock to lock with the front stabilizer bar. I decided to go with a 18x8 American racing AR95T with Nitto NT850+ CUV 235/60VR-18. Edited August 21, 2011 by coolram62 Quote Link to comment Share on other sites More sharing options...
