ODIMUS Posted August 16, 2011 Report Share Posted August 16, 2011 Hello All, I have an 09 SE. I'm looking at the MyGIG but not sure which one is for the Dodge. I saw one and it was listed at 2000$$$ Has anyone installed one or do they come factory??? Thanks. Quote Link to comment Share on other sites More sharing options...
19InBlkJrny Posted August 16, 2011 Report Share Posted August 16, 2011 Welcome ODIMUS There are some things you should know about MyGig radios. Most will work in your SE AS LONG as they are the same bus speed! Some Chrysler/Dodge vehicles have a low data bus and some (journey's) have high data bus speed. SO, the MyGig you buy will have to be high speed data bus. After that it's pretty much plug and play, UNLESS you purchase a model with navigation. In that case you will need the factory navigation antenna. Here check out this link, this site has a lot of good info about MyGig systems. Hope this helps Omar Quote Link to comment Share on other sites More sharing options...
ODIMUS Posted August 17, 2011 Author Report Share Posted August 17, 2011 On 8/16/2011 at 8:12 PM, 19InBlkJrny said: Welcome ODIMUS There are some things you should know about MyGig radios. Most will work in your SE AS LONG as they are the same bus speed! Some Chrysler/Dodge vehicles have a low data bus and some (journey's) have high data bus speed. SO, the MyGig you buy will have to be high speed data bus. After that it's pretty much plug and play, UNLESS you purchase a model with navigation. In that case you will need the factory navigation antenna. Here check out this link, this site has a lot of good info about MyGig systems. Hope this helps Omar Thanks Omar! I'll check it out :D Quote Link to comment Share on other sites More sharing options...
