bigtsr Posted December 5, 2013 Report Share Posted December 5, 2013 I had the disappearing oil problem but that was on a new 1985 Plymouth Voyager and it was the valve guides that were defective in the Mitsu engine they used. It used a liter of oil every 700 kms,dealer told me it was normal but I disagreed went to another dealer and sure enough a TSB was in the system. Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted December 6, 2013 Report Share Posted December 6, 2013 On 12/5/2013 at 4:55 AM, MWG said: Hi, No resolution. I've moved to far away to visit my dealership to keep up doing the oil consumption over and over again, I heard some people had new engines put in I guess they fought hard for it. Where did you hear about maybe a valve guide issue? It's to bad we can't get a answer. Is it the valve guides? Should I change to a synthetic oil? My car has over 100,000 Km now. Switching to synthetic will not help and I know it's taboo to use oil additives in our Journeys but a product like Lucas Heavy Duty oil stabilizer may help slow the oil consumption so you are not constantly filling it with oil. Now that you have moved have you tried going to a dealership near your area and see if they take the oil consumption more seriously? I think you are still in the powertrain warranty period? I would try to get it done and fight as hard as you can on the issue. Quote Link to comment Share on other sites More sharing options...
cotonymopar Posted December 20, 2013 Report Share Posted December 20, 2013 we have a 2009 R/T and it also uses too much oil, I am constantly checking it.. I have had 2 rams with over 130000 on both, any they never used a drop (5.7) now my wifes Journey uses a lot.. something has to be wrong with it.. the 09 has the limited lifetime powertrain warranty, but this is ridiculous.. something needs to be done about this... Quote Link to comment Share on other sites More sharing options...
7D6 Posted February 5, 2014 Report Share Posted February 5, 2014 Hi all, I have the 2010 Journey FWD R/T 3.5l and i am having the same issue with the oil running low. i have no idea where it is going but i have noticed that after about a 1000 miles the oil doesnt look like oil anymore, its looks like a charcoal color with soot in it and smells like exhaust. If i dont keep up with the oil atleast every fill up of gas the engine will start knocking real bad in the upper valve area. I find myself changing the oil every 1500 miles cause the oil just looks like friggen water. I am not impressed with the 3.5l I really miss my 2003 1500 dodge ram hemi. never had 1 issue with her. Quote Link to comment Share on other sites More sharing options...
mikeymouse Posted February 26, 2016 Report Share Posted February 26, 2016 I found a crap ton of oil in my air filter box. Replaced PCV, hope that works. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
cbrowne Posted July 7, 2016 Report Share Posted July 7, 2016 This is happening in my Grand Caravan (2011) about 3 litres per 5000km. It never used to do it. It does not burn blue, it does not leak. My mechanic changed PVC, and still same problem. Dodge says "normal". I say that's crap. This isn't my first car... never happened in any other vehicle. Did any one else who changed their PVC see results? If not, what did you do next? Thanks Quote Link to comment Share on other sites More sharing options...
jkeaton Posted July 7, 2016 Report Share Posted July 7, 2016 (edited) On 7/7/2016 at 2:27 AM, cbrowne said: cbrowne, on 06 Jul 2016 - 10:27 PM, said:This is happening in my Grand Caravan (2011) about 3 litres per 5000km. It never used to do it. It does not burn blue, it does not leak. My mechanic changed PVC, and still same problem. Dodge says "normal". I say that's crap. This isn't my first car... never happened in any other vehicle. Did any one else who changed their PVC see results? If not, what did you do next? Thanks Check a caravan forum. This forum is for Dodge Journeys. But maybe try a different "mechanic". That's such an old school term for technicians that actually know what they are doing. Edited July 7, 2016 by jkeaton Quote Link to comment Share on other sites More sharing options...
weasey31 Posted July 16, 2016 Report Share Posted July 16, 2016 I have 2009 3.5L. Bought it one year ago. I noticed same thing on my oil dipstick on periodic checks. It eats some oil and I have no leaks either. I thought the same thing with the coolant. There is no change in the color of coolant at the overflow reservoir. Hankster 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted July 16, 2016 Report Share Posted July 16, 2016 (edited) It is completely normal for an engine to use oil without leaking or burning between oil changes. The amount depends on a lot of factors. Edited July 16, 2016 by jkeaton Quote Link to comment Share on other sites More sharing options...
dhh3 Posted July 16, 2016 Report Share Posted July 16, 2016 I have just passed two years of ownership. I have never checked my oil! After reading this, maybe I should start. All oil changes have been done by my Dealer, and nothing has ever been said about missing oil between changes. Quote Link to comment Share on other sites More sharing options...
Scott Jordison Posted September 4, 2016 Report Share Posted September 4, 2016 I had a 2004 Intrepid with 3.5 engine which used about one liter every 5000 K. I now have a 2007 Sebring with 3.5 engine which uses approx. 1liter after first 3000 k from oil change then approx 1 liter every 2000 k after. This engine started using oil after approx 25000 Kim's. Chrysler mechanic said these engines have issues with oil rings gumming up which lets oil by the rings. If the engine has lots of city driving and is not driven at higher rpm this may happen more. Chrysler will not usually repair the engine unless consumption is more than one liter per 800 to 1000 km. Quote Link to comment Share on other sites More sharing options...
