How many MP3s can the 4.3 Uconnect handle?
Got my new ride on Monday. Stuck in an 8 Gig memory stick and the radio only sees the first 256 files . . do I need to put the songs in a subdirectory? Break them up into directories of 256 songs max each?
The manual is useless. It doesn't say anything and it doesn't diferentiate between standard features and options
Edited by bramfrank
I don't have any files that start with '0' - however it clearly only reads the first 255 of them - and they're alphabetic - so I get only the 'A' and 'B' songs and those that start with a digit.
Edited by bramfrank
Now I'm really unhappy . . . the dealer called the tech line and was told that 'there is no hard drive and so it can't handle many songs'.
Now THAT is a crock - there is an 8 Gig block of memory sitting in my USB key - and the songs sit there. Any limitations, should there really be any are due to poor coding.
It also doesn't forgive the impact that playing USB-based MP3s has on the controls and touchscreen of my 4.3
This is simply unacceptable. It ain't over yet. Maybe Dodge wants to buy me an iPod?
Not that I'm aware of. I usually leave my iPod plugged in, inside the console, and it makes the little power up sound (like when you plug it into a wall charger) every time I start the ignition. Although, worst case, it would only use power until the iPod finishes charging.
Mine seems to get power to the USB port any time I open a door. Right after any door is open, I can hear my iPod's power chirp. Not sure how long it stays on after the door is closed again.
