careful when driving on very dusty roads
frank b
Just a quick heads up
We were unlucky enough to get stuck behind a van on a dusty gravel road, I had a suv in front of me too. So the drive to get to the cabin was very dusty as you might expect.
It's a 90min drive on that gravel road, when we came back and got on the normal roads, the engine stalled and peaked at 4500rpm and I was hearing a weird woosh.
Got out of the car, took out the air filter which had collected so much dust that the engine cut the fuel @ 4500rpm because it wasn't getting enough air to go beyond that.
I cleaned it as best as I could on the side of the road.
I never really took notice of the airbox desing before that but where the intake opening sits right under the hood on the right, it's bound to suck in a lot of dust and even water. They should've made it end up a tad bit lower IMO.
So : if you plan on doing quite a bit of driving on them gravel roads, make sure you have an extra filter just in case !
Edited by frank b
Interesting as I drive the remaining 5 miles to my cottage on gravel roads. I will keep this in mind.
Terry
