Woodsey Posted October 19, 2011 Report Share Posted October 19, 2011 Has anyone else come across this issue...during colder mornings (anything below 8 degrees Celsius) upon first starting my car I have no AM/FM sound...there is sound for the CD, Sirius and GPS but not the radio. You then have to restart the car one or two times and it works. Pretty consistent issue each morning. I've had it in to the dealer twice...the first time they couldn't find anything wrong and just yesterday they replaced the amp as others have had done...but this morning, again no sound. Anybody else have this issue happen to them...any thoughts on what it might be...radio, wiring? 19InBlkJrny 1 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted October 19, 2011 Report Share Posted October 19, 2011 Your dealer needs a lesson in troubleshooting . . . . if you have sound from other sources, but not the radio, the problem will not be in the amplifier that is common to all of the I/O, but rather the with the component that houses the tuner or with the connections to the radio's antenna - probably a cracked trace on a circuit board or perhaps a poor connection to the antenna - a broken wire that makes the connection after the vibratio of starting - itt pulls open when the wires 'shrink' at night. 19InBlkJrny 1 Quote Link to comment Share on other sites More sharing options...
19InBlkJrny Posted October 19, 2011 Report Share Posted October 19, 2011 On 10/19/2011 at 3:18 PM, bramfrank said: Your dealer needs a lesson in troubleshooting . . . . if you have sound from other sources, but not the radio, the problem will not be in the amplifier that is common to all of the I/O, but rather the with the component that houses the tuner or with the connections to the radio's antenna - probably a cracked trace on a circuit board or perhaps a poor connection to the antenna - a broken wire that makes the connection after the vibratio of starting - itt pulls open when the wires 'shrink' at night. Bram is right, this is an issue with the radio or antenna, not the amplifier. Pretty sweet you got a new amp anyway. I would push them to replace the radio if this persists. This is something I've not heard of yet. Quote Link to comment Share on other sites More sharing options...
zmttoxics Posted October 20, 2011 Report Share Posted October 20, 2011 I too have this problem, but it wasn't just in the morning. I was thinking it was just mad at us for using the satellite radio for too long. If you get it fixed, I would love to know the solution! Quote Link to comment Share on other sites More sharing options...
Woodsey Posted October 21, 2011 Author Report Share Posted October 21, 2011 On 10/20/2011 at 6:00 PM, zmttoxics said: I too have this problem, but it wasn't just in the morning. I was thinking it was just mad at us for using the satellite radio for too long. If you get it fixed, I would love to know the solution! Mine is starting to do it after it has sat for a bit as the days are getting colder. I've also had the radio stations randomly change and the auto-climate control default to another setting. It's going back in on Monday and I am going to push them to replace the 8.4N unit as there is something wrong right across the board. I'll right a post when I know what they have done to fix the problem. Quote Link to comment Share on other sites More sharing options...
mrlux Posted October 21, 2011 Report Share Posted October 21, 2011 Fortunately I haven't had a problem with the radio but have had the A/C temp. control go up from what I had it set on. This was the first sign that the battery was going to be dead the next morning. Once I had the TSB for the battery issue done I haven't had a problem with the climate control or the battery. Quote Link to comment Share on other sites More sharing options...
Woodsey Posted October 25, 2011 Author Report Share Posted October 25, 2011 (edited) Update - had my Journey in for the 3rd time for the radio - the dealer thought it might have been a fuse and disconnected the battery to reset everything...big surprise...radio still not working this morning. I was instructed if it happened again that the dealer would finally order a new radio for it! Edited October 25, 2011 by Woodsey Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted October 25, 2011 Official Dodge Support Report Share Posted October 25, 2011 (edited) On 10/25/2011 at 1:16 PM, Woodsey said: Update - had my Journey in for the 3rd time for the radio - the dealer thought it might have been a fuse and disconnected the battery to reset everything...big surprise...radio still not working this morning. I was instructed if it happened again that the dealer would finally order a new radio for it! Woodsey, Did the dealer flash the new amplifier? If not it may have same problem as the old amplifier which may not have needed to be switched, just flashed. Below is the TSB on this issue. Perhaps it applies to your vehicle. Below that is another TSB relating to a no sound/power condition. Listing both because I do not know your VIN. NUMBER: 08-052-11 GROUP: Electrical DATE: August 27, 2011 SUBJECT: Flash: No Sound From Radio OVERVIEW: This bulletin involves flash reprogramming the Amplifier with new software. MODELS: 2011 - 2012 (JC) Journey 2011 - 2012 (LD) Charger 2011 - 2012 (LX) 300 NOTE: This bulletin applies to JC vehicles built prior to July 8, 2011 (MDH 0708XX) equipped with 368 Watt Amplifier (sales code RD6). NOTE: This bulletin applies to LD, LX vehicles built prior to July 25, 2011 (MDH 0725XX) equipped with 276 Watt Amplifier (sales code RD7) or 506 Watt Amplifier (sales code RFD). SYMPTOM/CONDITION: The customer may indicate that the audio system is muted or the audio does not play. NUMBER: 08-048-11 GROUP: Electrical DATE: August 06, 2011 SUBJECT: RHA And REB Radio Software Enhancements OVERVIEW: This bulletin involves upgrading the software on the RHA or REB Radio. MODELS: 2011 (JC) Journey NOTE: This bulletin applies to vehicles built prior to July 13, 2011 (MDH 0711XX) equipped with UCONNECT TOUCH 4.3 CD/MP3 (sales code RHA) or UCONNECT TOUCH 4.3S CD/MP3/SAT (sales code REB). SYMPTOM/CONDITION: · No display and no audio on radio. · The driver's heated seat soft key is grayed out on the radio display. · CD skips repeatedly while playing. · CD jumps tracks after cranking the engine, turning the radio off and then on, and/or after depressing the stop and then play soft key. · In USB playback mode a blank screen, or the last displayed screen, is displayed when the ABC soft key is pressed. · An iPod Nano connected in USB mode may fail to play and/or the Pause and Play keys are reversed on the radio display. · Multiple instances of the same Sirius Game Zone entry may be displayed. Edited October 25, 2011 by DodgeCares Quote Link to comment Share on other sites More sharing options...
Woodsey Posted October 26, 2011 Author Report Share Posted October 26, 2011 The amp that was originally installed was part of a batch that Dodge was having problems with...though I don't think it was the cause of the issues I was having, chances were good that it was going to act up. Update...my dealership has ordered a new 8.4N unit saying there is an internal issue not related to programing...I will make sure that they update the amp and radio when it installed. Quote Link to comment Share on other sites More sharing options...
Woodsey Posted November 2, 2011 Author Report Share Posted November 2, 2011 Update: They replaced my 8.4N unit on Monday...no issues this morning...hoping this has finally fixed a 2 month ordeal! Quote Link to comment Share on other sites More sharing options...
zmttoxics Posted November 7, 2011 Report Share Posted November 7, 2011 I just got back from my dealer. Apparently their test showed my problem was related to the radio not having my VIN programmed in. They programmed it in and reset everything and it seems to be working. They did not do the flashes listed above... They did do 2 RRTs though, 11-069 (PCM for long crank time) and 11-082 (BCM for the battery problems). Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted November 7, 2011 Official Dodge Support Report Share Posted November 7, 2011 On 11/7/2011 at 7:36 PM, zmttoxics said: I just got back from my dealer. Apparently their test showed my problem was related to the radio not having my VIN programmed in. They programmed it in and reset everything and it seems to be working. They did not do the flashes listed above... They did do 2 RRTs though, 11-069 (PCM for long crank time) and 11-082 (BCM for the battery problems). ZMT, I hope this solves your problem. Quote Link to comment Share on other sites More sharing options...
zmttoxics Posted December 19, 2011 Report Share Posted December 19, 2011 Just to add to this, my problem quickly returned after this. Too busy to take it back in for another round. Quote Link to comment Share on other sites More sharing options...
20journey11 Posted January 4, 2012 Report Share Posted January 4, 2012 I have no AM/FM when the Journey is first started. Shut the car off and restart and the radio starts working again. Took it to the dealer to have the radio reflashed. Since the radio has been flashed two times prior for other issues, they ordered a new radio. Quote Link to comment Share on other sites More sharing options...
zmttoxics Posted January 26, 2012 Report Share Posted January 26, 2012 Finally got some time to take it back in. It is going in on Monday to get looked at again. Quote Link to comment Share on other sites More sharing options...
zmttoxics Posted February 1, 2012 Report Share Posted February 1, 2012 They ordered the fm module i guess (not the 8.4 unit). I am sure it wont fix it, but atleast they are doing something now... Quote Link to comment Share on other sites More sharing options...
zmttoxics Posted February 7, 2012 Report Share Posted February 7, 2012 (edited) They replaced the "Radio / telematics gateway module", part number 5091134ZH. It was working when I left the dealership, we will have to see if it was the fix over time I guess (it's not super cold right now). Edit: Days later and still working! Edited February 10, 2012 by zmttoxics Quote Link to comment Share on other sites More sharing options...
TexasBob Posted December 20, 2013 Report Share Posted December 20, 2013 I'm having this same issue... is anyone else still having this issue? Quote Link to comment Share on other sites More sharing options...
fivepack Posted February 12, 2014 Report Share Posted February 12, 2014 I had this problem with my 2011 Journey. After several "unless we see it we don't believe it" responses (aka: loose nut behind the wheel), I finally managed to get it to the dealer while it was misbehaving. Since the problem was then finally verified, they started working on it. The car spent more time with the dealer than with me. I would get it back, and the next cold morning -- nada. The dealer finally replaced the radio with one that had almost the same serial number, and it did not fix the problem (surprise?). After that, they kept it for a week (and paid for the rental car). They finally replaced the radio a second time, and that seemed to fix it. It did however, break the IPOD features. I figured I could live without being able to control the IPOD from the screen, since I used it mainly on long trips and I was very tired of the dealership. However, it is now 13 months later, and this morning -- no AM/FM again. I think I need to get rid of this car. I can't go through another round of back and forth with the dealer.Too bad. Otherwise I like the car. But I need the radio for the traffic reports. Quote Link to comment Share on other sites More sharing options...
harrisjohn6 Posted February 12, 2014 Report Share Posted February 12, 2014 Sounds like a design flaw, I rarely use the AM/FM radio mostly my iPod for music so if it does happen to me I would not know about it until my iPod died on me. Quote Link to comment Share on other sites More sharing options...
