humansoul Posted October 31, 2011 Report Share Posted October 31, 2011 Hey DJF....just wondering if anyone has changes their tires by themselves with a jack stand and what jack points you used. I've personally looked under the vehicle to determine the jack points and noticed underneath the front of the vehicle has a rubber puck looking thing. This appears to be bolted on to the body frame; but can't determine if this is an engine mount or an actual jack point we can use. As for the rear of the Journey, I have a dual exhaust Journey, so I cannot seem to be able to use to cross beam on the rear, but instead, I have to use the connecting point of the control arm, where the cross beam meets it....I hope that makes sense. Of course, I will be using axle stands for both the rear, but I just want to ensure I jack up the car at the right points. I observed this set up on a 2011 Dodge Journey Crew, I cannot comment on any previous years or models. if anyone can assist, that would be appreciated! Thanks! Quote Link to comment Share on other sites More sharing options...
Armendegga Posted November 6, 2011 Report Share Posted November 6, 2011 I believe the rubber puck that you are referring to is in fact the motor mount. Unless it's changed for the Journey, I believe the jack points are on the metal panel that runs lengthwise along the Journey... Usually it's a few inches behind the front tire on each side, and a few inches infront on the back. Quote Link to comment Share on other sites More sharing options...
humansoul Posted November 8, 2011 Author Report Share Posted November 8, 2011 Well that's a bummer...it's a pain, and somewhat more dangerous, to raise one side at a time rather than having it be equal on both the front and rear of the Journey. I guess I'll ask the service dept and see if they can point out what points, if any, I can use. Quote Link to comment Share on other sites More sharing options...
Armendegga Posted November 23, 2011 Report Share Posted November 23, 2011 I know there definitely are jackpoints underneath because that's how they do them at most places when they change the tires by putting it on a hoist, I just don't know what it is Quote Link to comment Share on other sites More sharing options...
