Easy Posted November 29, 2011 Report Share Posted November 29, 2011 I watched a video on youtube the other day and it looked like Dodge went away from the LED tail lights on the 2012 model. I almost didn't want to believe it, but yesterday I saw one on the road: could it be true? Are those regular tail lights, just like they were on the pre-2011 models? Quote Link to comment Share on other sites More sharing options...
ChrisPollard Posted November 29, 2011 Report Share Posted November 29, 2011 The LEDs come on the SE and up models. The base Canada Value Package (and I assume the American Value Package as well) use standard tail lights. My CVP has incandescents. The SE Plus I looked at had LEDs. Quote Link to comment Share on other sites More sharing options...
bramfrank Posted November 29, 2011 Report Share Posted November 29, 2011 (edited) Just for accuracy, in Canada at least the CVP was the SE in 2011. They seem to have dropped the SE moniker for 2012, at least according to the Canadian web site - LEDs come on the SE PLUS and above. Not sure why they call it a 'plus' in Canada if they no longer have an SE. There is no badge identifying Canadian 'plus' models - you need to check the exterior styling cues. In both Canada and the US the CVP/AVP come with regular bulbs and the SE (SE plus in Canada) is the model above the base and have LED tail lights, roof rails (with crossbars in Canada) and more. What you get for your extra money in each country is as follows Canada: LED Tail Lights Tinted windows Roof rack side rails WITH crossbars Leather wrapped steering wheel & shifter 17" alloy wheels Floor mats Body coloured mirrors retractable cargo cover US: LED Tail Lights Tinted windows Roof rack side rails (NO crossbars) To get body colored mirrors, floor mats, 17" wheels and such you need to take it up to the SXT in the US - which also gives you the six cylinder engine (with dual exhausts and six speed tranny), fog lights, standard Sirius-equipped radio and more aggressive looking front bumper/grill. Why they option them so differently is beyond me. I'm sure they have their reasons - it does seem as though the upgrade to the SE/SE Plus is a much better value proposition in Canada than it is in the US. Then again, the Canadian Journey outsells the US one by a huge margin on a per capita basis - could this be why? Quick question: The US brochure states that the TPS system simply says OK, Hi or Low for pressure indication. My SE Plus shows actual tire pressure values (albeit in 7 kpa steps) on the EVIC - do US models show numbers? Or is the American TPS simply an idiot light setup? Edited November 29, 2011 by bramfrank Quote Link to comment Share on other sites More sharing options...
generaltso Posted November 29, 2011 Report Share Posted November 29, 2011 Quick question: The US brochure states that the TPS system simply says OK, Hi or Low for pressure indication. My SE Plus shows actual tire pressure values (albeit in 7 kpa steps) on the EVIC - do US models show numbers? Or is the American TPS simply an idiot light setup? The American version does show numbers (in PSI). Quote Link to comment Share on other sites More sharing options...
burgandy25 Posted November 20, 2012 Report Share Posted November 20, 2012 here in Michigan I saw on the showroom floor a new one without LEDs, this make me think that maybe there is hope that we could put in the 2011+ LED taillights in the older than 2011 journeys. Quote Link to comment Share on other sites More sharing options...
bramfrank Posted November 21, 2012 Report Share Posted November 21, 2012 The one you saw was likely an AVP - those don't come with LED lighting - but don't expect to be able to retrofit the LED for incandescent - different wiring harnesses . . . . Quote Link to comment Share on other sites More sharing options...
acgiorgio Posted November 21, 2012 Report Share Posted November 21, 2012 Quick question: The US brochure states that the TPS system simply says OK, Hi or Low for pressure indication. My SE Plus shows actual tire pressure values (albeit in 7 kpa steps) on the EVIC - do US models show numbers? Or is the American TPS simply an idiot light setup? I don't understand what the logic is to having the TPMS in 7kpa intervals in the Canadian version. If they were gonna do that why didnt they just leave it in PSI? I understand that PSI is USA and kpa is CAD but this means that a change of 1 PSI would be visible on the display but a change of 6 kpa would not. You would be able to see on the TPMS a change from 36psi to 35psi, however on a change from 255kpa to 249kpa you would not know. WTF? Quote Link to comment Share on other sites More sharing options...
bramfrank Posted November 21, 2012 Report Share Posted November 21, 2012 1 psi is slightly less than 7 kpa - the TPS transmitter clearly is calibrated in individual steps of PSI and the display allows approximating kpa on the display, which is why it moves in 7 kpa steps . . . . my old LHS has a TPMS that reads in individual steps of 1 kpa - damned accurate, too. Quote Link to comment Share on other sites More sharing options...
