Sander Zwart Posted December 23, 2011 Report Share Posted December 23, 2011 (edited) We just or owners of a Journey 2.4 SXT and we already have a problem with our Journey. When we start the engine the following hapens: - the fuel indicator says no more fuel but the fuel tank is half filled; - the RPM indicator says no RPM, but the engine is working; - the speedometer says no speed, but we are driving.. - there is a alarm bieb; - a lot of warning lamps are burning. After a while the situation is over and there are no problems. Turn of engine does not help. Can anybody tell me what the cause is? Computer problems? Thanks in advance. Sander Update: I get a notice in the dahboard; no bus. Edited December 23, 2011 by Sander Zwart Quote Link to comment Share on other sites More sharing options...
bramfrank Posted December 23, 2011 Report Share Posted December 23, 2011 It could be a fuse. I could be computer issue or it could be a loose connector to the gauge cluster (in no particular order, though I would check for a burned fuse before doing anything else). I suspect your dealer will need to check it out. Quote Link to comment Share on other sites More sharing options...
Sander Zwart Posted January 9, 2012 Author Report Share Posted January 9, 2012 I put it on a video. See Youtube: Quote Link to comment Share on other sites More sharing options...
bigtsr Posted January 10, 2012 Report Share Posted January 10, 2012 What year Journey is it? The reason I ask is that marginal battery can cause many funny faults. Quote Link to comment Share on other sites More sharing options...
Armendegga Posted January 10, 2012 Report Share Posted January 10, 2012 That is completely bizarre. It's almost like there's a short somewhere or something that's causing it. You should try taking it into the dealer for sure. Quote Link to comment Share on other sites More sharing options...
Sander Zwart Posted January 10, 2012 Author Report Share Posted January 10, 2012 The Journey is from 08-2008. 103.000km Quote Link to comment Share on other sites More sharing options...
bigtsr Posted January 11, 2012 Report Share Posted January 11, 2012 2008 and if it is original battery that could be your culprit as they seldom are reliable past 3.5 yrs given your climate. Quote Link to comment Share on other sites More sharing options...
