help shifter is stuck in park
mikenichol123
i had a remote starter installed and every thing was fine and when it was time to be pulled out the shifter was locked. remote starter is disconnected and still does it . the traction control and brake assistance lights are on in the dash. there is power at the brake switch and brake lights come on when pedal is pressed. basically the shifter solonied is not getting power to release the shifter. any clue anyone ive checked all the fuses and they are all good.
Sounds as if the installer messed up your DJ can.t help other to suggest
you bite the bullet and get it to dealer and if you read the manual it tells
you how to manually release the shifter lock solenoid,on the MY11 it's
in the console storage box not sure about the MY10.
  • 6 months later...
  • 1 year later...
As the Manuel shows a plastic pink thing well guess its not there its must of broke and fell off but I move the spring forward and she shiftes why are they still using a defective part in these cars as it only a matter of time before its breaks some models were on a recall for this so they know the plastic part is defective should start a class action law
It's a common problem across all Chrysler products. It's a little plastic lever that breaks over time from use. It's like this thing.
http://www.ebay.com/itm/DODGE-CHRYSLER-SHIFTER-INTERLOCK-LEVER-SPRING-AND-CLIP-REPLACEMENT-MOPAR-OEM-/151211887369?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AChrysler
Edited by jkeaton
I have the same problem with my DJ 2010 shifter stuck in park we took the plastic molding off around the shifter and use screw driver to move shifter the pink plastic thing was broke off no longer there it's seem this is a problem with dodge they contine to use this defect part in there cars recalling some models we all should get a law suit against them for this as why recall some models and not the others that have the same problem
It is not a safety related issue so no recall. Class action suits against big corporations are a waste of time and resources. Lawyers get rich, thats about it.
