Where is the fuel pump please?????????????///??
aram4477
Yes, most, if not all, modern fuel injected engines have the fuel pump in the fuel tank.
I can't quite believe a fuel pump has failed or needs replacement already.....
That said, you should not let the fuel get low (below 1/8 tank) on a consistent basis. The fuel actually helps keep the fuel pump cool. Running with low fuel levels can burn the pump up.
