wrxz24 Posted January 16, 2012 Report Share Posted January 16, 2012 Just wondering if anyone is experiencing squeaking, clunk sound as they are closing the door? It acts as it is catching a little on the hinge and it makes a clunk, grind sound as it passes the point on the hinge. No, I haven't tried grease yet. Quote Link to comment Share on other sites More sharing options...
bigtsr Posted January 16, 2012 Report Share Posted January 16, 2012 Yes generally the noise from door position roller and detent assy,I use white Lithium based automotive grease to quiet it down. Quote Link to comment Share on other sites More sharing options...
wrxz24 Posted January 16, 2012 Author Report Share Posted January 16, 2012 Awfully big door on the J's I think. Will try the white lithium grease. Quote Link to comment Share on other sites More sharing options...
Dre Posted April 2, 2012 Report Share Posted April 2, 2012 (edited) Yup same grinding/clunking noise here on all four doors...it seems worst since the DJ has gone through winter and has gotten a bit better with milder weather but I suppose that's normal. I tried white lithium lube but didn't help much. I'll have to try some grease on there I guess. Edited April 2, 2012 by Dre Quote Link to comment Share on other sites More sharing options...
symbasys Posted April 2, 2012 Report Share Posted April 2, 2012 I use bulb grease - the clear kind that comes in a small tube. It's thick so it stays put, plus since it's clear it doesn't make a mess. I used it on all 4 door strikers and latches to quiet the door shift noise when going over uneven pavement. Quote Link to comment Share on other sites More sharing options...
