2010 Windshield loose/noise
Anyone noticed an improperly sealed front windshield? I have a 2010 r/t.
On COLD (Canadian COLD) winter days on highway drives of several hours the front windshield seems to make noises when hitting highway bumps. A rattle almost. Seems to be mainly from high passenger center of windshield.
Like maybe the heat differential from 2 hours of DEFROST on the inside and terrific cold on the outside has broken the seal.
Never hear it when driving in town.
  • 1 year later...
I don't think it is the windshield being "loose"...if the seal was broken in an area, it would leak, but, wouldn't rattle. That laminated plate glass is very rigid and very heavy. Most likely you have a loose wiring harness or bracket under the headliner that, in very cold temperatures, shrinks a bit and allows a rattle. There are a lot of wires that travel all over the car under that headliner and can rattle in the right conditions. A good dealership can probably track it down, but, my WAG is something under the headliner and not the windshield, especially if it isn't leaking...
Keep us posted on what you find...
