Skittles019 Posted June 20, 2008 Report Share Posted June 20, 2008 Does anyone know when K & N will be coming out with an air filter for the Journey? I always put these in my cars it increases fuel economy and performance. Quote Link to comment Share on other sites More sharing options...
tool6996 Posted June 23, 2008 Report Share Posted June 23, 2008 I added myself to their mailing list and they are supposed to email me once it does. They gave no ETA Quote Link to comment Share on other sites More sharing options...
Mopar54 Posted June 23, 2008 Report Share Posted June 23, 2008 I am going to check into this more. Does anyone know if the air filter for the Journey is the same size as the air filter for the 3.5L V6 Avenger. It appears to be the same shape, but I haven't gotten out the ruler to check dimensions. I'm almost at 9000 miles on the Journey and need to replace mine soon. John Quote Link to comment Share on other sites More sharing options...
aharris1482 Posted December 17, 2008 Report Share Posted December 17, 2008 Does anyone know when K & N will be coming out with an air filter for the Journey? I always put these in my cars it increases fuel economy and performance. I did a cross reference of the stock filter and K&N filter 33-2206 should fit. Advance auto parts list the oem filter "35396" (which also fits a 2007 dodge caravan) and 33-2206(k&N) is the equivalent. Quote Link to comment Share on other sites More sharing options...
Gunny Posted January 11, 2009 Report Share Posted January 11, 2009 I did a cross reference of the stock filter and K&N filter 33-2206 should fit. Advance auto parts list the oem filter "35396" (which also fits a 2007 dodge caravan) and 33-2206(k&N) is the equivalent. Have you picked one up yet? Quote Link to comment Share on other sites More sharing options...
BigCountry Posted January 16, 2009 Report Share Posted January 16, 2009 I picked mine up today. Works great. A couple things to be aware of though: First, the gasket that is included with the unit is specifically for the caravan. The Journey does not have a recess along the edge of the top plenum, therefore you do not need to add the gasket. If it is added I suspect that there would be a possibility for air to get through by-passing the filter. The second item to note is that like any K&N filter, the rubber portion of the filter is a few millimeters thicker than that of the OEM resulting in a little tighter fit. You have to really push on the clips (clips are a dodge design suit the purpose, but not the best engineering) to get them up over the lip. I used a pair of pliers to aid in this. This is the second vehicle I have purchased a filter for, had one on my truck for years now, it is also a tight fit. Quote Link to comment Share on other sites More sharing options...
Gunny Posted January 16, 2009 Report Share Posted January 16, 2009 I picked mine up today. Works great. A couple things to be aware of though: First, the gasket that is included with the unit is specifically for the caravan. The Journey does not have a recess along the edge of the top plenum, therefore you do not need to add the gasket. If it is added I suspect that there would be a possibility for air to get through by-passing the filter. The second item to note is that like any K&N filter, the rubber portion of the filter is a few millimeters thicker than that of the OEM resulting in a little tighter fit. You have to really push on the clips (clips are a dodge design suit the purpose, but not the best engineering) to get them up over the lip. I used a pair of pliers to aid in this. This is the second vehicle I have purchased a filter for, had one on my truck for years now, it is also a tight fit. What is the K&N Part Number your using Big? Quote Link to comment Share on other sites More sharing options...
BigCountry Posted January 19, 2009 Report Share Posted January 19, 2009 I used the 33-2206. It worked well. Quote Link to comment Share on other sites More sharing options...
toolscake Posted March 24, 2009 Report Share Posted March 24, 2009 Sorry but will this (33-2206) fit 2.4 I-4? Quote Link to comment Share on other sites More sharing options...
WREED6223 Posted April 8, 2009 Report Share Posted April 8, 2009 Be aware that the Purolator PA35396 gasket is thicker than the OEM and when the tech from Advance Auto Parts installed the second filter because the first would not fit, he tore the gasket pushing the air box cover in place and and had to force the retainer clips in place. Got a refund and will purchase air filter from Dodge. I also cannot find the cabin filter so I guess that will come from Dodge also. Wild Bill Quote Link to comment Share on other sites More sharing options...
mikem Posted April 10, 2009 Report Share Posted April 10, 2009 I also cannot find the cabin filter so I guess that will come from Dodge also.Wild Bill I got my Journey without the cabin air filter, and just picked one up at the dealership. I'm in Canada, and it was only around $25. Quote Link to comment Share on other sites More sharing options...
larryl Posted April 11, 2009 Report Share Posted April 11, 2009 I agree with wild Bill the Purolator does not fit Quote Link to comment Share on other sites More sharing options...
WREED6223 Posted April 12, 2009 Report Share Posted April 12, 2009 I agree with wild Bill the Purolator does not fit I went to the Dodge dealership and got the air filter($26.90) and cabin filter($20.17). A bit pricey as the after markets are about 50% less. Air filter fit just fine. Anyone notice how much dirt was in the bottom of the air box? Bad intake location behind the grill, maybe? I'm going to write to Purolaor and find out why the air filter does not fit and why they don't make a cabin filter. Let you know what I hear. Set for another 12,000 miles. Quote Link to comment Share on other sites More sharing options...
BAC Posted April 12, 2009 Report Share Posted April 12, 2009 Does anyone know if you can get one for the European 2.0 Diesel engine? Cheers! Quote Link to comment Share on other sites More sharing options...
WOLF Posted April 14, 2009 Report Share Posted April 14, 2009 BAC, are you after the filter for the extra power or economy, or what exactly!!! Quote Link to comment Share on other sites More sharing options...
Remline Posted April 16, 2009 Report Share Posted April 16, 2009 I went to the Dodge dealership and got the air filter($26.90) and cabin filter($20.17). A bit pricey as the after markets are about 50% less. Air filter fit just fine. Anyone notice how much dirt was in the bottom of the air box? Bad intake location behind the grill, maybe? I'm going to write to Purolaor and find out why the air filter does not fit and why they don't make a cabin filter. Let you know what I hear. Set for another 12,000 miles. Just went to my dealer yesterday. they quoted me $18.40 + tax for the cabin filter. Quote Link to comment Share on other sites More sharing options...
JourneyMan71 Posted April 17, 2009 Report Share Posted April 17, 2009 I am waiting on cold air intake for it,from K&N. On my Caliber I did the MOPAR header, K&N CAI, and MagnaFlow exhaust,it runs better now, and sounds meaner,lol. I like it. I would like to do similar thing to the Journey. I just hope they sell enough to warrent these upgrades. Quote Link to comment Share on other sites More sharing options...
SUV-TELE Posted April 30, 2009 Report Share Posted April 30, 2009 Thanks guys for the heads up on the K&N filter part number. Bought it and put it in the other day. Abit of a pain to sqeeze the air box top back on. But manageable. Here is a question though. When I switch the OEM filter on my bike to the K&N I had to change the jets in my carbs to compensate for the extra air flow going through it. Doing this to the SUV now. Being a fuel injected engine. Is this not a factor now at all ? I can't say my engine runs worser. I could feel a slight better accelleration in the lower gears though. Maybe its my imagination. Quote Link to comment Share on other sites More sharing options...
BigCountry Posted May 4, 2009 Report Share Posted May 4, 2009 No you do not have to perform any upgrades to the injectors or intake. All new vehicles are equipped with a mass air flow sensor which will automatically adjust your fuel ratio for the amount of air passing through\by it. You would only have to perform modifications to this system if you were going to bolt on major performance upgrades like a super charger. Quote Link to comment Share on other sites More sharing options...
JourneyMan71 Posted May 6, 2009 Report Share Posted May 6, 2009 No you do not have to perform any upgrades to the injectors or intake. All new vehicles are equipped with a mass air flow sensor which will automatically adjust your fuel ratio for the amount of air passing through\by it. You would only have to perform modifications to this system if you were going to bolt on major performance upgrades like a super charger. I am not sure about the Journey,but my 2007 Caliber 2.0L does not have a MAF sensor. I was told Chryslers do not use them. Like I said not sure about the Journey. It being 2 MY newer and all. Quote Link to comment Share on other sites More sharing options...
SUV-TELE Posted May 10, 2009 Report Share Posted May 10, 2009 No you do not have to perform any upgrades to the injectors or intake. All new vehicles are equipped with a mass air flow sensor which will automatically adjust your fuel ratio for the amount of air passing through\by it. You would only have to perform modifications to this system if you were going to bolt on major performance upgrades like a super charger. Thanks for clearing that up. Quote Link to comment Share on other sites More sharing options...
jbauto3 Posted May 27, 2009 Report Share Posted May 27, 2009 K&N filter is out part # 33-2423 Just put it in & it fits Quote Link to comment Share on other sites More sharing options...
JEANNA'sJOURNEY Posted July 29, 2009 Report Share Posted July 29, 2009 Yes...the closing of the top lid is a bit challenging with the 33-2206...and with one person trying to do it...I had to be smarter than the task @ hand. Used a 3" C clamp to compress the closure together / you have a very small lip to get ahold of on the airbox...but it worx better than trying to press it down manually, and hook the clip @ the same time. Hope this helps! Quote Link to comment Share on other sites More sharing options...
jbauto3 Posted July 30, 2009 Report Share Posted July 30, 2009 Yes...the closing of the top lid is a bit challenging with the 33-2206...and with one person trying to do it...I had to be smarter than the task @ hand.Used a 3" C clamp to compress the closure together / you have a very small lip to get ahold of on the airbox...but it worx better than trying to press it down manually, and hook the clip @ the same time. Hope this helps! I would make sure you have the right filter because mine fit just like the factory one. I had no problems closing it. Quote Link to comment Share on other sites More sharing options...
JourneyMan71 Posted September 21, 2009 Report Share Posted September 21, 2009 I ordered my K&N air filter for my Journey on Saturday 9-19-09 part number 33-2423. It said on K&N's website it fits all engines 2.0L Diesel and both 2.4L & 3.5L gas engines. Quote Link to comment Share on other sites More sharing options...
