Mohammadsen Posted May 7, 2012 Report Share Posted May 7, 2012 Hey guys I've had a squeaky window since thursday. I thought it would go but it hasn't. Any tips? Quote Link to comment Share on other sites More sharing options...
silentdan Posted July 7, 2012 Report Share Posted July 7, 2012 Hey guys I've had a squeaky window since thursday. I thought it would go but it hasn't. Any tips? Just saw this thread and had to reply.I have the same issue with my drivers side window.It makes a awfull squeaky sound when going up or down. I have to figure a way to stop this as is anoying as hell. Quote Link to comment Share on other sites More sharing options...
Mohammadsen Posted July 8, 2012 Author Report Share Posted July 8, 2012 It is very and still no fix found ill keep you updated Quote Link to comment Share on other sites More sharing options...
silentdan Posted July 8, 2012 Report Share Posted July 8, 2012 It is very and still no fix found ill keep you updated Thanks man let me know if you find a solution. Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted July 8, 2012 Report Share Posted July 8, 2012 If your vehicle is still under warranty then take it back to the dealer as they may need to open the door panel to lubricate or replace whatever is the culprit inside.....if your out of warranty a temporary fix would be to use some silicone lubricant spray along the bottom window weather strip track. Quote Link to comment Share on other sites More sharing options...
dodgefan Posted July 8, 2012 Report Share Posted July 8, 2012 I had the same issue back in November 2011...they replaced the weather stipping on the drivers window and it solved the problem. About two weeks ago the drivers window has again started to squeek again, so back I go. Quote Link to comment Share on other sites More sharing options...
Mohammadsen Posted July 9, 2012 Author Report Share Posted July 9, 2012 The delar did nothing.... as usual Quote Link to comment Share on other sites More sharing options...
bigtsr Posted July 9, 2012 Report Share Posted July 9, 2012 If it is indeed the rubber causing the squeaking you can buy a silicon base rubber/weather strip treatment/lubricant and apply it with a Q-tip to see if that quiets it down. You might want to try taking a thin slice of quality hand soap and rub it in the rubber grove, I have a clothes dryer that the rubber drive belt starts squeaking every 6 months and handsoap shuts it up. Quote Link to comment Share on other sites More sharing options...
dodgefan Posted July 13, 2012 Report Share Posted July 13, 2012 I had my car at at the dealershipo yesterday. They are replcing the window weather stripping around the drivers window under warranty of course. Parts ordered yesterday and they are in today, appointment booked to have to done on Tuesday ...super fast. Quote Link to comment Share on other sites More sharing options...
