jakesclark08 Posted May 8, 2012 Report Share Posted May 8, 2012 I just changed the oil in my 09 and the change oil light nev er went off. So I looked in the owners manuel to se how to rest it, and came across the part where you have to turn the acc. On and depress the gas peddle 3 times, the turn the key to lock. Worked, but now im getting a wooping 14 maybe 15 mpg. Any thoughtz?.. I have checked fluids and filter... All good Quote Link to comment Share on other sites More sharing options...
bigtsr Posted May 8, 2012 Report Share Posted May 8, 2012 Well I don't know if you caused this but to reset you set to RUN with no start and depress the pedal,again they may have reset the EVIC mpg and it will take time and milage to get your averages down to readings you had before as it takes longer for averages to go down. Quote Link to comment Share on other sites More sharing options...
OhareFred Posted May 8, 2012 Report Share Posted May 8, 2012 Not to be a wise guy, but are you sure you used the correct weight oil? If you used 10/30 your m p g will suffer. Quote Link to comment Share on other sites More sharing options...
