Darryl78 Posted May 29, 2012 Report Share Posted May 29, 2012 Good evening folks, My journey is now 6 months old, and this is the first time that've have been able to enjoy the AC, So when the AC first runs for about the first 5 - 10 mins It has a sour smell, it happens almost every time we use it, after those first 5 - 10 minutes it's all gone, and dosent return untill we use it again the next time. Any thoughts on this before a trip to the dealer? Is it normal for the initial runs of AC and will it go away?? Thanks for your time Darryl Quote Link to comment Share on other sites More sharing options...
Psyke Posted May 29, 2012 Report Share Posted May 29, 2012 Found this for you: http://www.ehow.com/info_12164279_cars-c-smell-bad.html cheers! Steph S. Quote Link to comment Share on other sites More sharing options...
bigtsr Posted May 30, 2012 Report Share Posted May 30, 2012 Pull the cabin filter out and spray it (lightly) with Fabreze or alternately put a FEW drops of your favourite car deodourizer on it.I done this a few times thru the years. Quote Link to comment Share on other sites More sharing options...
Darryl78 Posted May 30, 2012 Author Report Share Posted May 30, 2012 Thaanks Steph and big, will look into that this weekend Cheers Quote Link to comment Share on other sites More sharing options...
Fdavey55 Posted May 30, 2012 Report Share Posted May 30, 2012 I had this same issue with a Toyota I once had. If you use the recirculation feature then condensation tends to build up in the vents, when you shut the vehice off then all that moisture just pools and sits. If left it will cause a musty / sour smell. I found if you turn the recirc off on the last 2-3 miles of your drive it will dry things out and eliminate the smell. It took about a week to fully get rid of it but it worked. Like bigtsr, I too have Febreezed my cabin filter, it works well but you need to elimnate the moisture also. Good Luck! Quote Link to comment Share on other sites More sharing options...
probak118 Posted May 31, 2012 Report Share Posted May 31, 2012 (edited) Live next to a Chrysler Mech, air conditioning specialist. He has always told me to run the air with fresh air setting for the first 4 -5 minutes to remove / eliminate the formation of condensation in the vents. Then, switch setting to recirculate and there should not be an issue.. Sounds like that is exactly what is happening, Edited May 31, 2012 by probak118 Quote Link to comment Share on other sites More sharing options...
twinx1649 Posted March 1, 2024 Report Share Posted March 1, 2024 Foul Interior Odor Finally Found. It is the dash silencer pad. I've owned this low miles 2014 Journey for a while and haven't been able to pinpoint the foul smell in the interior. I FINALLY removed the seats, carpeting, and center console and found it's the mastic/dash silencer. Since I wasn't going to roll the I.P. to remove the entire silencer, I ripped out everything I could get my hands on. I did replace it with Dynamat and jute as a replacement silencer. NO MORE STINK!!! 2late4u 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted March 2, 2024 Report Share Posted March 2, 2024 12 year old thread these people probably wont see this.... Quote Link to comment Share on other sites More sharing options...
