PhillipPop Posted July 3, 2012 Report Share Posted July 3, 2012 Hello, I am new here and have a 2011 Mainstreet. I'm from Detroit, Michigan, but residing in Augusta, Georgia. Here to keep up on newest trends with the car and looking into Known problems. I have mine in the shop for the second time in 2 weeks, check engine and traction control lights. First time they said it was related to a cam sensor and there was a TSB fix. Have to wait and see what it is this time. I have 15,000 miles on the car. Phillip "Semper Fi" Quote Link to comment Share on other sites More sharing options...
bigtsr Posted July 3, 2012 Report Share Posted July 3, 2012 Cam sensors will turn on check engine light but not sure what they would have to do with traction control. 15000 miles so you have had at least 2 oil changes and unless you have them done at a dealer (I may be wrong) putting the wrong viscosity oil in will play havoc with a VVT engine giving you varied faults. Let us know whats found. Quote Link to comment Share on other sites More sharing options...
PhillipPop Posted July 3, 2012 Author Report Share Posted July 3, 2012 Cam sensors will turn on check engine light but not sure what they would have to do with traction control. 15000 miles so you have had at least 2 oil changes and unless you have them done at a dealer (I may be wrong) putting the wrong viscosity oil in will play havoc with a VVT engine giving you varied faults. Let us know whats found. Do my own oil changes every 3500-4000 miles after the oil change warning goes off, full synthetic 5w30. Got a voice mail from the service rep. He said parts were put on order, but didn't specify what. Because of the 4th, they'll be in on the 5th and I should hopefully have the car back Thur or Fri. WE shall see. I will update then. Quote Link to comment Share on other sites More sharing options...
