PhillipPop Posted July 6, 2012 Report Share Posted July 6, 2012 1- Had my 2011 Mainstreet in the shop all this week. Started 2 weeks ago. Out of nowhere Check engine and the Traction Control light went off. Took it in, same day fix. Code P054A, P054C-Cam advance too far, Fix covered under TSB18-037-11. Flashed PCM. 2- This past Monday morning, same thing- engine and traction control lights. Service ticket info below: 3.4- code P0340, Cam position sensor circuit bank 1 sensor 1. Star case to replace exhaust cam phasers both heads. Replaced (2) camshaft phasers and both head gaskets. Picked it up Friday afternoon. Hopefully this is the end of the engine problems. I'm planning a trip to Michigan soon. Quote Link to comment Share on other sites More sharing options...
Moparman Posted July 7, 2012 Report Share Posted July 7, 2012 Yeah there was some issue with bad phasers on the 11s. Doesn't seem to be a reoccuring problem, nor effect 12s Quote Link to comment Share on other sites More sharing options...
RobertRoth Posted May 29, 2019 Report Share Posted May 29, 2019 (edited) I need to know which product is the best from the ones listed on the site? Edited May 30, 2019 by jkeaton 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Armando G Posted May 29, 2019 Report Share Posted May 29, 2019 (edited) On 5/29/2019 at 10:05 PM, RobertRoth said: I need to know which product is the best from the ones listed on the site? Expand Pick the pedal that makes your car go faster Edited May 30, 2019 by jkeaton Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 30, 2019 Report Share Posted May 30, 2019 On 5/29/2019 at 10:05 PM, RobertRoth said: I need to know which product is the best from the ones listed on the site? Expand Bye Felicia. mechanical-idiot 1 Quote Link to comment Share on other sites More sharing options...
